1. Output of caddy version:
v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
via Debian systemd, this works without problems
(this is only excerpt relevant to my problem, not a full config)
http://radio.example.org, https://radio.example.org {
reverse_proxy http://localhost:8000
I serve both HTTP and HTTPS because
I have private internet radio (hence I redacted domain names) powered by Icecast 2 behing Caddy proxy (for HTTPS and additional security).
The problem is that song names are not updated. These are served at /status-json.xsl route by Icecast.
I am not sure if this is somewhat being cached by Caddy or if this is some mishap on Icecast side. If this is cached by Caddy, how do I disable cache? I found out flush_interval settings in docs, but I am not sure if “The proxy buffers responses by default for wire efficiency” means that responses are being cached.
forcing Icecast to update song name manually, this worked sometimes
