apitman
(Anders Pitman)
1
Basically what’s in the title. I see the docs for the Caddyfile format but haven’t been able to locate it for the JSON config yet.
It’s particularly confusing because apparently there used to be a third party plugin for this which is now deprecated.
EDIT: I forgot caddy adapt
was a thing. Based on the output, looks like I’ll have to set this up manually with rewrites and headers?
Yep, caddy adapt
is the best way to get started with JSON config if you know what you’re trying to do with a Caddyfile.
Pretty much. The Caddyfile docs explains what the forward_auth
config shortcut does forward_auth (Caddyfile directive) — Caddy Documentation, it’s essentially just a reverse_proxy
with some defaults set up.
system
(system)
Closed
3
