The way is build as a caddy module, is there other ways?
Welcome Jonathan, good question.
I don’t think we’ve had a request for this before. What is your use case?
But yes, I think a module would be able to do it. (Could be third-party. Doesn’t need to be part of Caddy’s standard/official distribution.)
Thanks to your response.
I’m trying to add a build in web UI to caddy.
The way i see is to create a module in http.handlers.
Before I start, ask the community if I have better choise.
Yeah, an HTTP handler module is how you should do it. Caddy is designed around the config (see Architecture — Caddy Documentation), so you need to provide a module that does what you need and plug it into the config.
I made it. Thanks.
