Is there a way to better group this Caddyfile?
Here is my Caddyfile snippet:
	handle /api/* {
		reverse_proxy http://myserver:3030
	handle_path /app1/* {
	handle_path /app2/* {
Since the proxy server is same, So I want to use named matcher to simplifie these Caddyfile, such as:
	@myserver {
		path /api/*
		path /app1/*
		path /app2/*
	handle @myserver {
But this is not right because app1 and app2 was use handle_path .
I searched the document but can’t find the right way to achive this.
caddy 2.7.4
ubuntu 22.04
handle and handle_path are not the same. Are you intending to strip the matched path, or not?
That said, you can write your path matcher as a one liner like this:
@myserver path /api/* /app1/* /app2/*
The path /api/* and /app1/* have different processing logic. /api requires the use of handle, but /app1/* and /app2/* require the use of handle_path, so is there a simple way to handle this?
You could do this I guess:
	uri /app1/* strip_prefix /app1
	uri /app2/* strip_prefix /app2
	reverse_proxy myserver:3030
All paths will go to your proxy, but your app paths will have their prefix stripped first.
If you have more than two apps then you could do:
	@apps path_regexp apps ^(/app[0-9]+)(.*)$
	rewrite @apps {re.apps.2}
This would match a path with any app number and rewrite it to the remainder of the path (i.e. (.*) the 2nd capture group)
