Is it safe to change key_type on a running machine with already issued certificates?
This is more of an information query than asking for help but oh well :slight_smile:
For a request with a customer we need to generate Json web tokens tied to a certificate, and they require it with specific details (RSA up to 2048bit), not self-signed. The machine currently has Caddy and a handful of DNS records already working well, with the default key type (ed25519 it seems). So i want to use the certificades Caddy generates (On /var/lib/caddy/.local/share/caddy/certificates/acme-v02.api.letsencrypt.org-directory/domainname) since they’re fully valid and working, and even tied to the right domain name.
If i now manually set the key_type to “rsa2048”, will i cause harm? Or regenerate every certificate? Or just start affecting the next issued/renewed certificates? Or will it break something?
v2.7.4 on Debian 11
From the repository for Debian machines
This.
You could delete your existing certs from storage then restart Caddy to force re-issuance with the new key type.
