Hello I’m curious if it’s possible to use programs like Shynet (https://github.com/milesmcc/shynet) with Caddy. I was able to use it pretty easily with Nginx but I haven’t been able to find out exactly how it can be done with Caddy.
So i’ve got the plugin set up now I’m just not sure about how the syntax should go. The examples use words like “Foo” so its a bit unclear how i’m to input something with characters like <> or quotations. I tried it like this which is definitely wrong and is throwing errors. I added
{"level":"info","ts":1626049959.4685297,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
run: adapting config using caddyfile: parsing caddyfile tokens for 'replace': /etc/caddy/Caddyfile:222 - Error during parsing: Wrong argument count or unexpected line ending after 'defer'
{"level":"info","ts":1626049960.4398599,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1626049961.4446237,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1626049962.4865465,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
