Is it possible to use caddy as an LDAPS proxy?
We currently use caddy as a reverse proxy for our services. What’s new is that I need to make our LDAP server available to an external application with an SSL certificate.
I have found examples on the net that I can use nginx as an LDAPS proxy server, but I can’t find anything on whether this is also possible with caddy.
Is this possible with Caddy and if so, how?
2. Caddy version:
2.8.4
Ubuntu 22.04.3 LTS
Docker version 26.0.1, build d260a54
docker compose up -d caddy
c. compose file:
    image: caddy:alpine
    restart: always
      - 443:443
      - /data/caddy/data:/data
      - /data/caddy/Caddyfile:/etc/caddy/Caddyfile
      - /data/nextcloud/html:/var/www/html
      - /data/nextcloud/apps:/var/www/html/custom_apps
      - /etc/timezone:/etc/timezone:ro
    links:
      - nextcloud-app:nextcloud-app
      - nextcloud-push:nextcloud-push
      - proxy-net
cloud.mydomain.com {
	php_fastcgi nextcloud-app:9000 {
		#                env modHeadersAvailable true
		#                env front_controller_active true
		trusted_proxies private_ranges
	root * /var/www/html
	header Strict-Transport-Security max-age=15552000;
	redir /.well-known/carddav /remote.php/dav/ 301
	redir /.well-known/caldav /remote.php/dav/ 301
	@forbidden {
		path /.htaccess
		path /.xml
		path /3rdparty/*
		path /config/*
		path /data/*
		path /db_structure
		path /README
		path /lib/*
		path /templates/*
		path /occ
		path /console.php
		path /test.php
	respond @forbidden "Access denied" 403 {
		close
	handle_path /push/* {
		#      rewrite * {path}
		reverse_proxy http://nextcloud-push:7867
mail.mydomain.com {
	reverse_proxy 192.168.0.10:80
mailer.mydomain.com {
	reverse_proxy 192.168.0.14:80
Here is an example of how this could be solved with nginx:
Caddy is an HTTP server. LDAP is not HTTP. So it’s not possible with Caddy’s standard distribution.
But you could use GitHub - mholt/caddy-l4: Layer 4 (TCP/UDP) app for Caddy which is a TCP/UDP layer server.
