For example, instead of:
:81 {
tls /etc/xxx/xxx.crt /etc/xxx/xxx.key
proxy / 127.0.0.1:8080 {
:82 {
:443 {
Can we do something like:
:81 - 443 {
OR even:
:81, :82, :83, ..., :443 {
I’ve tried :81-443 with caddy 1.x and there is an error parsing the config file.
The error message I received:
● caddy.service - Caddy HTTP/2 web server
Active: failed (Result: exit-code) since Wed 2020-02-19 03:27:05 UTC; 10s ago
Docs: https://caddyserver.com/docs
Process: 19996 ExecStart=/usr/local/bin/caddy -log stdout -log-timestamps=false -agree=true -conf=/etc/caddy/Caddyfile -root=/var/tmp (code=exited, stat
Main PID: 19996 (code=exited, status=1/FAILURE)
Feb 19 03:27:05 worker-96 systemd[1]: Started Caddy HTTP/2 web server.
Feb 19 03:27:05 worker-96 caddy[19996]: [INFO] Caddy version: v1.0.4
Feb 19 03:27:05 worker-96 caddy[19996]: error inspecting server blocks: parse //:81-443: invalid port ":81-443" after host
Feb 19 03:27:05 worker-96 systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Feb 19 03:27:05 worker-96 systemd[1]: caddy.service: Failed with result 'exit-code'.
