With nginx it can be done like this
Furthermore, it is possible to change the response code to another using the “=response” syntax, for example:
error_page 404 =200 /empty.gif;
Is there a way to do it with caddy?
Just to make sure I understand, you want to serve a 404 page with a status of 200?
Actually i need a setup where every non-existent (app-)route is mapped to root/index and this might be the most simple way …
Like what rewrite
does?
rewrite {
to {path} /
If the file at {path}
doesn’t exist, it will route the request to root.
Thanks, but i also use the proxy.
Example
proxy /api/db/ localhost:3000 { without /api/db/ }
With rewrite i would have to exclude all those proxy entries somehow. Is this right?
With the “special” 404 this would not be necessary.
