Is DNS challenge possible with freedns.afraid.org?
I want to have my certificates to my internal services renew without having to open ports. My DNS provider is freedns.afraid dot org which is on the easily integrate list but not in the caddy modules list.
This freedns.afraid.org docker image could automate getting the certificates but the certificates need to be in caddy.
I’m a caddy noob so sorry if this is obvious. This tutorial explains it for cloudflare which is on the caddy modules list.
2. Workaround:
Manually open/forward ports host by host roughly every 80 days and restart caddy then close the ports after certificate renewal is done for another 80 days.
Hi @Linguini9394,
That shows only acme.sh and Posh-ACME as the only ACME Clients.
Also while being a helpful list, sometimes a taking it with a grain of salt can be prudent.
Edit:
The suggested Workaround only works for non-wildcard certificates,
as wildcard certificates can only be issued via DNS-01 challenge (well at least for Let’s Encrypt).
The docker-certbot-freedns mentioned in the OP provides certbot support through a --manual-auth-hook script. Does certbot support for freedns help?
Good point, I’m not using any wildcard certificates which are not free on freedns.
Good question, probably best asked on GitHub - TRPB/docker-certbot-freedns: A docker image for DNS certbot renewals for freedns.afraid.org their support channels.
Also there is that grain of salt I mentioned.
It seems freedns has limitations according to Posh-ACME.
Any suggestions for free DNS providers known to work well with caddy’s letsencrypt DNS challenge certificate renewals?
Kindly wait for more knowledgeable Caddy community volunteers to assist.
Hi @Linguini9394,
Here is a free DNS provider
https://desec.io/
I’ve migrated one host which uses acme.sh from freedns to duckdns and DNS challenge certificate renewal with no open ports works.
I have two other hosts using caddy in a docker container that I’ll try to migrate next to duckdns or deSEC as both are on the caddy modules list. Caddy in docker is a black box to me that just works so it will take some learning…
In conclusion I gave up on freedns (doesn’t do free dns challenge) and duckdns (unreliable free dns challenge) and bought a cheap 1.111B Class domain and manage it with free cloudflare.
This caddy-cloudflare docker image allowed me to migrate my two html challenge caddy hosts to dns challenge.
To get it to work I had to add a Caddyfile where the vanilla caddy docker image was working in html challenge without me adding one.
{$DOMAIN} {
        # Proxy everything to Rocket
        reverse_proxy myappcontainer:80
                dns cloudflare {$CLOUDFLARE_API_TOKEN}
Time to enjoy automatic certificate renewals with no open ports in my homelab.
Yeah, I wish they’d allow subdomains and TXT challenges for free. It’s unfortunate that it doesn’t. I’ve had a domain with afraid for like 15 years or so and I found it handy for a DDNS CNAME to my real domain. Though these days using GitHub - mholt/caddy-dynamicdns: Caddy app that keeps your DNS records (A/AAAA) pointed at itself. is even nicer, it supports dynamic DNS for any domain which has a DNS plugin (including Cloudflare etc).
I haven’t found DuckDNS to be unreliable at all. I’ve used it for nearly a decade without any major issues.
That said, your own domain with Cloudflare is a perfectly good solution.
