@matt If we have more than one requests are accessing caddy server at the same time , what is is the process caddy used to generate certificates for multiple domains, Sequential or Parallel?
Cert issuance is done in parallel, but there is rate limiting built-in to avoid stampeding.
More detail in the docs:
Francis is right; Caddy can obtain as many certs at once as allowed by rate limits and throttling.
If two clients request a cert for the same domain at the same time, only one cert will be obtained, and both will unblock once the cert is ready.
This topic was automatically closed after 29 days. New replies are no longer allowed.
