Latest version
Docker image on windows.
Windows Server 2019, Docker
Paste command here.
Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
matt
(Matt Holt)
May 31, 2022, 5:56am
2
I think so? You’ll have to be more specific. There’s different versions of FIPS.
I believe PCI DSS requires some form of FIPS compliance, and Caddy is PCI-DSS compliant:
https://www.immuniweb.com/ssl/caddyserver.com/lI5hzHft/
Okay. Any version of FIPS support is fine for me. Thank you @matt
Mohammed90
(Mohammed Al Sahaf)
May 31, 2022, 11:26am
4
The certification isn’t about the software itself, rather it’s about the system overall and how you configure the various software/components that make up the system. FIPS seems to allow only a subset of ciphers and algorithms . At first glance, it seems that Caddy’s default config should be compliant out of the box (see list of ciphers on this page: tls (Caddyfile directive) — Caddy Documentation ).
