Is Caddy mutating header content from logging settings?
I’m attempting to hash sensitive headers in access logs via logging settings. Per the documentation, I should be able to change the format and hash them, which - while it works - appears to also be changing the headers to their hashed values to reverse proxy endpoints?
Here’s the example Caddyfile:
		format filter {
			wrap json
			fields {
				request>headers>X-Test hash
	reverse_proxy http://127.0.0.1:1337
Here’s my reverse proxy listener:
$ nc -l 1337
And here’s my request:
$ curl localhost -H'X-Test:"test one two three"'
Here’s what my caddy run logs (after I Ctrl-C the simple netcat listener):
{"level":"error","ts":1693016089.716869,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"127.0.0.1","remote_port":"43332","client_ip":"127.0.0.1","proto":"HTTP/1.1","method":"GET","host":"localhost","uri":"/","headers":{"User-Agent":["curl/8.1.1"],"Accept":["*/*"],"X-Test":["338145b3"]}},"bytes_read":0,"user_id":"","duration":0.000283437,"size":0,"status":502,"resp_headers":{"Server":["Caddy"]}}
And here’s what the reverse proxied endpoint (netcat) sees:
GET / HTTP/1.1
Host: localhost
User-Agent: curl/8.1.1
Accept: */*
X-Forwarded-For: 127.0.0.1
X-Forwarded-Host: localhost
X-Forwarded-Proto: http
X-Test: 338145b3
Accept-Encoding: gzip
As you can see I don’t get test one two three from Caddy but the hashed value instead as it appears in the logs, as if the header itself is being mutated, not only at log time.
I grabbed the latest stable release from GitHub to reproduce the issue.
Just nabbed a GitHub release.
I’m on NixOS but the caddy I got was statically linked so I don’t think there’s anything unique here.
./caddy run
I just ran it manually.
		format filter {
			wrap json
			fields {
I’m following the log documentation, but maybe I’m misunderstanding how this works? In any event I’m surprised to find the header altered just from making logging changes.
Update: it appears that this is only happening with the hash action - using directives like delete work as expected.
You’re right, that’s a bug. Go is pretty tricky. We thought we were modifying a copy of the headers but it’s not a copy :grimacing: So we’ll need to copy the header values when transforming them which has a tiny performance impact from making an allocation but :man_shrugging: it’s what we gotta do I think.
Thank you @francislavoie, I appreciate the triage and fix :pray:
