Title says it all. I know caddy is a go application, I read here (oss-security - Fwd: Protecting against CVE-2026-98432 when using Go programs) that go applications use mptcp by default for listening on TCP ports.
Hey, from what I’ve read this is a linux kernel issue rather than a caddy specific vulnerability.
The Go security team says Go 1.24+ enables MPTCP listeners by default on linux.
GODEBUG=multipathtcp=0is a possible temporay mitigation, but it doesn’t fix the underlying kernel bug.
Their recommendation is to update to a patched host kernel. So, here’s their advisory:
The linux distribution we are using have yet to publish a patched kernel…
Ok then, quick workaround from the Go security team is to set GODEBUG=multipathtcp=0 for any Go 1.24+ applications.
Disabling MPTCP at the kernel level is another option. Neither actually fixes the vulnerability in the kernel. I would also check your distros security advisories, for backported patches than relying only on the kernel version of the distro.
Which distro and release are you running?
I am running ubuntu, which this time is surprisingly slow at releasing this security patch.
We’ve set the environment variable as far as I’m aware
