- The problem I’m having:
I want specific subdomains to be either IPv4 or IPv6 only.
My overall goal is that I run a service that relies on the X-Forwarded-For header to show the client’s IP address. My server has both IPv4 and IPv6, but Caddy always forwards the IPv6 address when it’s available. I need to be able to access the client’s IPv4 as well, without disabling IPv6 entirely. So I want to make dedicated v4/v6 subdomains but I don’t know how…
- Error messages and/or full log output:
I can’t provide logs for it, since I can’t figure out how can I even do this. Currently everything responds to both v4 and v6.
- Caddy version:
caddy version
v2.10.0
- How I installed and ran Caddy:
I used xcaddy to build it with caddy-dns/cloudflare.
xcaddy build --with github.com/caddy-dns/cloudflare
Debian 12 (Linux x86_64), with systemd – no docker.
Domain: (*.)example.com
cat /lib/systemd/system/caddy.service
Type=notify
ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile --force
Environment="CLOUDFLARE_API_KEY=REDACTED"
Restart=on-failure
RestartSec=5s
caddy fmt /etc/caddy/Caddyfile
(cf) {
dns cloudflare {env.CLOUDFLARE_API_KEY}
*.demo.example.com {
import cf
@demo host app.demo.example.com
handle @demo {
reverse_proxy 10.0.0.10:3006
abort
example.com {
import cf
reverse_proxy 10.0.0.14:3000
.example.com {
import cf
import sites/
redir https://example.com permanent
Example from my sites/ directory:
cat /etc/caddy/sites/service.example.com
@service host service.example.com
handle @service {
reverse_proxy 10.0.0.10:8002
- Links to relevant resources:
