iphash
(ip)
1
I’m trying to load balance. Regarding the ip_hash policy, if one backend fails, does caddy automatically switch to an alternative backend?
It seems that it doesn’t in my tests. Is there a way to enable this functionality? Thank you.
Example config below. In another example, I added unhealthy_status 429
, but the failover seems to not work neither.
reverse_proxy {
to a:123
to b:123
to c:123
lb_policy ip_hash
lb_try_duration 5s
lb_try_interval 1s
fail_duration 30s
max_fails 3
Docker on Debian ARM64
Docker compose up
Please try v2.7.5 which we’ve released this week, it might fix the behaviour you’re seeing.
iphash
(ip)
3
Thanks. I tried the new version, and the issue persists.
It seems that when the policy is ip_hash, failover is not enabled at all. Should I open an issue about this feature?
Enable the debug
global option and show your logs. It should show the upstream selection logic.
iphash
(ip)
5
Thank you. I think the problem is that the failover is not enabled for existing visitors (who have an assigned load balancer already)
I’m not sure what you mean. Please show your logs, etc.
system
(system)
Closed
7
