2.3.0
Ubuntu 18.04.5 LTS
systemd
baremetal
installed package from deb repo https://dl.cloudsmith.io/public/caddy/stable/deb/debian
systemctl start caddy.service
cat /lib/systemd/system/caddy.service
#Bind admin endpoint on all interfaces
admin 0.0.0.0:2019
on_demand_tls {
interval 1s
burst 100
# Redirect any accesses using an IP instead of a domaine name
# hackerone report: https://hackerone.com/reports/723126
51.91.128.49:80,
91.121.37.140:80,
147.135.229.201:80
redir https://app.lemlist.com{uri}
(cloadflare_matchers) {
remote_ip 103.21.244.0/22
remote_ip 103.22.200.0/22
remote_ip 103.31.4.0/22
remote_ip 104.16.0.0/12
remote_ip 108.162.192.0/18
remote_ip 131.0.72.0/22
remote_ip 141.101.64.0/18
remote_ip 162.158.0.0/15
remote_ip 172.64.0.0/13
remote_ip 173.245.48.0/20
remote_ip 188.114.96.0/20
remote_ip 190.93.240.0/20
remote_ip 197.234.240.0/22
remote_ip 198.41.128.0/17
remote_ip 2400:cb00::/32
remote_ip 2606:4700::/32
remote_ip 2803:f800::/32
remote_ip 2405:b500::/32
remote_ip 2405:8100::/32
remote_ip 2c0f:f248::/32
remote_ip 2a06:98c0::/29
(front_servers) {
to localhost:42001
to localhost:42002
to localhost:42003
to localhost:42004
to localhost:42005
to localhost:42006
to localhost:42007
to localhost:42008
health_path /api/ping
health_interval 1s
health_timeout 5s
# Main application
app.lemlist.com
level INFO
output file /var/log/caddy/front.log {
roll_size 100MiB
format console
# route keyword is mandatory to force Caddy to keep our
# directives order instead of using the Caddy builtin order
route {
request_body {
max_size 20MB
@from_cloudflare {
import cloadflare_matchers
@not_from_cloudflare {
not {
# pass all api lempire (e, i) requests to one
# dedicated Meteor app process
@api_e_i {
#path /campaigns/*
path /api/lempire/*
header @api_e_i {
X-Cache-Debug "app.api_e_i"
Server ""
reverse_proxy @api_e_i {
to localhost:8000
# pass all api requests to Meteor api process
@api {
#path /campaigns/*
path /api/*
header @api {
X-Cache-Debug "app.api"
Server ""
reverse_proxy @api {
to localhost:42100
# Caches
# must be after /api routes or https://app.lemlist.com/api/froala/files/*.jpg will not be served by meteor
@cache_app {
path *.svg *.woff2 *.eot *.ttf *.woff *.jpg *.jpeg *.png *.gif *.ico *.html
header @cache_app {
# 1d expiration
Cache-Control max-age=86400
X-Cache-Debug "app.cache"
Server ""
file_server @cache_app {
root /opt/lemlist/app/programs/web.browser/app
@cache_app2 {
path_regexp ^/lib/.*\.(map|js|css)$
header @cache_app2 {
# 1d expiration
X-Cache-Debug "app.cache2"
Server ""
file_server @cache_app2 {
@cache_version {
path_regexp ^/[0-9a-z]+\.(js|css|map).*
header @cache_version {
# 1d expiration
X-Cache-Debug "app.cache_version"
Server ""
file_server @cache_version {
root /opt/lemlist/web.browser
# Anything else goes to Meteor fronts
header * {
X-Cache-Debug "app.main"
Server ""
reverse_proxy @from_cloudflare {
header_up X-Real-IP {http.request.header.CF-Connecting-IP}
header_up X-Forwarded-For {http.request.header.CF-Connecting-IP}
import front_servers
lb_policy header CF-Connecting-IP
reverse_proxy @not_from_cloudflare {
lb_policy ip_hash
handle * {
respond 404
handle_errors {
@errors {
expression {http.error.status_code} == '502'
rewrite @errors /{http.error.status_code}.html
file_server {
root /var/www
#dev only : to work on laptop localhost
#tls internal
# Custom domaines
(custom_domaines) {
level INFO
output file /var/log/caddy/custom_{args.0}.log {
roll_size 100MiB
format console
route {
# render a special page when on root so the user can see if
# its custom domain is correctly setted up
header / {
X-Cache-Debug "custom.cname_ok"
Server ""
rewrite / /lemlist_cname_ok.html
file_server /lemlist_cname_ok.html {
root /var/www
# pass all requests "track open/click" to track
@track {
path_regexp ^/api/(t/c|track/open|reply)/
header @track {
X-Cache-Debug "custom.track"
Server ""
reverse_proxy @track {
to localhost:42160
# pass all requests "images + pages" to images
@images {
path /*
header @images {
X-Cache-Debug "custom.images"
Server ""
reverse_proxy @images {
to localhost:42140
handle * {
respond 404
# WARNING : DO NOT add any other site address than :443 here
:443
import custom_domaines on_demand
on_demand
issuer acme {
email cert@lempire.co
timeout 180s
dir https://acme.zerossl.com/v2/DV90
eab 3....w V....Q
issuer acme {
timeout 180s
dir https://acme-v02.api.letsencrypt.org/directory
pages.lemlist.com,
lemlst.org,
lemlst.eu,
lmlst.com
import custom_domaines predefined
# WARNING : DO NOT add any other site address than :80 here
:80
import custom_domaines port80
# public direct access to service
(public_passthrough) {
{args.0}
level INFO
output file /var/log/caddy/public_passthrough/{args.0}.log {
roll_size 100MiB
format console
route {
request_body {
max_size 20MB
header * {
X-Cache-Debug "{args.0}.main"
Server ""
reverse_proxy * {
to localhost:{args.1}
import public_passthrough api.lemlist.com 42100
import public_passthrough img.lemlist.com 42150
import public_passthrough front.lempire.co 8000
# private direct access to services
(private_passthrough) {
front.lempire.co:{args.0}
level INFO
output file /var/log/caddy/private_passthrough/{args.0}.log {
roll_size 100MiB
format console
route {
@cache_version {
# 1d expiration
X-Cache-Debug "direct.cache_version"
Server ""
header * {
X-Cache-Debug "direct.main"
Server ""
reverse_proxy * {
basicauth * {
a...z J...D
# Fronts
import private_passthrough 43001 42001
import private_passthrough 43002 42002
import private_passthrough 43003 42003
import private_passthrough 43004 42004
import private_passthrough 43005 42005
import private_passthrough 43006 42006
import private_passthrough 43007 42007
import private_passthrough 43008 42008
# API
import private_passthrough 43100 42100
# Cron
import private_passthrough 43130 42130
# Images
import private_passthrough 43140 42140
# Images Front
import private_passthrough 43150 42150
# Track
import private_passthrough 43160 42160
Hello,
We use Caddy in production for now 1.5 month, it runs very well, but we got a persistent “issue” with on_demand tls certificate generation.
We provide vanity domains for our thousands of customers. for ex : foobar.bigcorp.com that is pointing to our server custom.lemlist.com where Caddy is running.
Unfortunately, we got a lot of “waiting on internal rate limiter” and “context deadline exceeded” (see logs), and so we are only able to generate 1 certificate every 5 - 10 minutes. Which is not enough in our case.
Using the following snippet, I can estimate to about 50 the number of tls_on_demand per minute:
timeout 60 journalctl -fu caddy | grep "\"obtaining new certificate"
My supposition, is that we hit a Caddy internal rate limiter, and when the wait for this rate limit ends, if it took more than 90 seconds, then we got a “context deadline exceeded” and the whole request stop.
If it takes less than 90s to wait for the rate limiter AND waiting for CA answer then the process succceed and we got certificate.
So, the main question is : Where do you think, the limit comes from ? Caddy or CA ?
How can we improve this ? Or where should we investigate to ?
Filtered log of a successful try:
Mar 23 15:27:46 front caddy[28894]: {"level":"info","ts":1616509666.1737103,"logger":"tls.on_demand","msg":"obtaining new certificate","server_name":"baaaaa.lempi.re"}
Mar 23 15:27:46 front caddy[28894]: {"level":"info","ts":1616509666.1739392,"logger":"tls.obtain","msg":"acquiring lock","identifier":"baaaaa.lempi.re"}
Mar 23 15:27:46 front caddy[28894]: {"level":"info","ts":1616509666.1739995,"logger":"tls.obtain","msg":"lock acquired","identifier":"baaaaa.lempi.re"}
Mar 23 15:27:46 front caddy[28894]: {"level":"info","ts":1616509666.174333,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["baaaaa.lempi.re"]}
Mar 23 15:28:50 front caddy[28894]: {"level":"info","ts":1616509730.161438,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["baaaaa.lempi.re"]}
Mar 23 15:28:51 front caddy[28894]: {"level":"info","ts":1616509731.5251303,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"baaaaa.lempi.re","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
Mar 23 15:28:55 front caddy[28894]: {"level":"info","ts":1616509735.2210684,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"baaaaa.lempi.re","challenge":"http-01","remote":"91.199.212.132:59328"}
Mar 23 15:29:12 front caddy[28894]: {"level":"info","ts":1616509752.039788,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"baaaaa.lempi.re"}
Mar 23 15:29:12 front caddy[28894]: {"level":"info","ts":1616509752.039803,"logger":"tls.obtain","msg":"releasing lock","identifier":"baaaaa.lempi.re"}
Mar 23 15:29:12 front caddy[28894]: {"level":"warn","ts":1616509752.0859249,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [baaaaa.lempi.re]: parsing OCSP response: ocsp: error from server: unauthorized"}
Filtered log of a failling try:
Mar 23 15:30:25 front caddy[28894]: {"level":"info","ts":1616509825.5424554,"logger":"tls.on_demand","msg":"obtaining new certificate","server_name":"oooo.lempi.re"}
Mar 23 15:30:25 front caddy[28894]: {"level":"info","ts":1616509825.5427058,"logger":"tls.obtain","msg":"acquiring lock","identifier":"oooo.lempi.re"}
Mar 23 15:30:25 front caddy[28894]: {"level":"info","ts":1616509825.542906,"logger":"tls.obtain","msg":"lock acquired","identifier":"oooo.lempi.re"}
Mar 23 15:30:25 front caddy[28894]: {"level":"info","ts":1616509825.5434377,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["oooo.lempi.re"]}
Mar 23 15:31:50 front caddy[28894]: {"level":"info","ts":1616509910.2317042,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["oooo.lempi.re"]}
Mar 23 15:31:51 front caddy[28894]: {"level":"info","ts":1616509911.573187,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"oooo.lempi.re","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
Mar 23 15:31:55 front caddy[28894]: {"level":"error","ts":1616509915.543706,"logger":"tls.issuance.acme.acme_client","msg":"deactivating authorization","identifier":"oooo.lempi.re","authz":"https://acme.zerossl.com/v2/DV90/authz/kIjx4bBZilb8M1LZcqriQA","error":"request to https://acme.zerossl.com/v2/DV90/authz/kIjx4bBZilb8M1LZcqriQA failed after 1 attempts: context deadline exceeded"}
Mar 23 15:31:55 front caddy[28894]: {"level":"info","ts":1616509915.5439215,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["oooo.lempi.re"]}
Mar 23 15:31:55 front caddy[28894]: {"level":"info","ts":1616509915.5439365,"logger":"tls.obtain","msg":"releasing lock","identifier":"oooo.lempi.re"}
Raw logs
Mar 23 15:56:47 front caddy[28894]: {"level":"info","ts":1616511407.6534648,"logger":"tls.on_demand","msg":"obtaining new certificate","server_name":"email.spear.agency"}
Mar 23 15:56:47 front caddy[28894]: {"level":"info","ts":1616511407.6536934,"logger":"tls.obtain","msg":"acquiring lock","identifier":"email.spear.agency"}
Mar 23 15:56:47 front caddy[28894]: {"level":"info","ts":1616511407.653772,"logger":"tls.obtain","msg":"lock acquired","identifier":"email.spear.agency"}
Mar 23 15:56:47 front caddy[28894]: {"level":"info","ts":1616511407.6543267,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["email.spear.agency"]}
Mar 23 15:56:47 front caddy[28894]: {"level":"info","ts":1616511407.6683092,"logger":"tls.on_demand","msg":"obtaining new certificate","server_name":"link.breaktheweb.agency"}
Mar 23 15:56:47 front caddy[28894]: {"level":"info","ts":1616511407.668565,"logger":"tls.obtain","msg":"acquiring lock","identifier":"link.breaktheweb.agency"}
Mar 23 15:56:47 front caddy[28894]: {"level":"info","ts":1616511407.6686497,"logger":"tls.obtain","msg":"lock acquired","identifier":"link.breaktheweb.agency"}
Mar 23 15:56:47 front caddy[28894]: {"level":"info","ts":1616511407.6692038,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["link.breaktheweb.agency"]}
Mar 23 15:56:48 front caddy[28894]: {"level":"info","ts":1616511408.0006843,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["trail.coachfoundations.com"]}
Mar 23 15:56:48 front caddy[28894]: {"level":"info","ts":1616511408.000721,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["trail.coachfoundations.com"]}
Mar 23 15:56:48 front caddy[28894]: {"level":"warn","ts":1616511408.000765,"logger":"tls.issuance.acme.acme_client","msg":"HTTP request failed; retrying","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","error":"performing request: Head \"https://acme-v02.api.letsencrypt.org/acme/new-nonce\": context deadline exceeded"}
Mar 23 15:56:48 front caddy[28894]: {"level":"error","ts":1616511408.0007906,"logger":"tls.obtain","msg":"will retry","error":"[trail.coachfoundations.com] Obtain: [trail.coachfoundations.com] creating new order: fetching new nonce from server: context deadline exceeded (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":90.000031017,"max_duration":2592000}
Mar 23 15:56:48 front caddy[28894]: {"level":"info","ts":1616511408.0008008,"logger":"tls.obtain","msg":"releasing lock","identifier":"trail.coachfoundations.com"}
Mar 23 15:56:48 front caddy[28894]: {"level":"info","ts":1616511408.2327697,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["track.princekapoor.com"]}
Mar 23 15:56:48 front caddy[28894]: {"level":"info","ts":1616511408.2327998,"logger":"tls.obtain","msg":"releasing lock","identifier":"track.princekapoor.com"}
Mar 23 15:56:48 front caddy[28894]: {"level":"info","ts":1616511408.3311765,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["trail.prodej-ambulance.cz"]}
Mar 23 15:56:48 front caddy[28894]: {"level":"info","ts":1616511408.3312006,"logger":"tls.obtain","msg":"releasing lock","identifier":"trail.prodej-ambulance.cz"}
Mar 23 15:56:48 front caddy[28894]: {"level":"info","ts":1616511408.9315224,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["t.mythemeshop.com"]}
Mar 23 15:56:49 front caddy[28894]: {"level":"info","ts":1616511409.5016632,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["track.turbocyclist.com"]}
Mar 23 15:56:50 front caddy[28894]: {"level":"info","ts":1616511410.135758,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"t.mythemeshop.com","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
Mar 23 15:56:50 front caddy[28894]: {"level":"info","ts":1616511410.1389298,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["track.merchantchimp.com"]}
Mar 23 15:56:50 front caddy[28894]: {"level":"info","ts":1616511410.1656828,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["track.happy-customers.com.au"]}
Mar 23 15:56:50 front caddy[28894]: {"level":"info","ts":1616511410.2341647,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["track.ado.media"]}
Mar 23 15:56:50 front caddy[28894]: {"level":"info","ts":1616511410.2341998,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["track.appexmedia.com"]}
Mar 23 15:56:50 front caddy[28894]: {"level":"info","ts":1616511410.6608245,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"track.turbocyclist.com","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.2468774,"logger":"tls.on_demand","msg":"obtaining new certificate","server_name":"track.rvsmedia.co.uk"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.2478786,"logger":"tls.obtain","msg":"acquiring lock","identifier":"track.rvsmedia.co.uk"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.2486346,"logger":"tls.obtain","msg":"lock acquired","identifier":"track.rvsmedia.co.uk"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.2506652,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["track.rvsmedia.co.uk"]}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.329539,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"track.happy-customers.com.au","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.3366666,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"track.merchantchimp.com","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.4144146,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"track.appexmedia.com","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.4346058,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"track.ado.media","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.5841262,"logger":"tls.on_demand","msg":"obtaining new certificate","server_name":"track.giftingmade.com"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.584895,"logger":"tls.obtain","msg":"acquiring lock","identifier":"track.giftingmade.com"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.5855772,"logger":"tls.obtain","msg":"lock acquired","identifier":"track.giftingmade.com"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.5871668,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["track.giftingmade.com"]}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.6053195,"logger":"tls.on_demand","msg":"obtaining new certificate","server_name":"tracking.growthstrategy.co.za"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.6061482,"logger":"tls.obtain","msg":"acquiring lock","identifier":"tracking.growthstrategy.co.za"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.60678,"logger":"tls.obtain","msg":"lock acquired","identifier":"tracking.growthstrategy.co.za"}
Mar 23 15:56:51 front caddy[28894]: {"level":"info","ts":1616511411.6084485,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["tracking.growthstrategy.co.za"]}
Mar 23 15:56:52 front caddy[28894]: {"level":"warn","ts":1616511412.7253697,"logger":"tls.issuance.acme.acme_client","msg":"HTTP request failed; retrying","url":"https://acme.zerossl.com/v2/DV90/authz/fg27oHe9Gc1wHjw5r-xBOw","error":"performing request: Post \"https://acme.zerossl.com/v2/DV90/authz/fg27oHe9Gc1wHjw5r-xBOw\": context deadline exceeded"}
Mar 23 15:56:52 front caddy[28894]: {"level":"error","ts":1616511412.7253914,"logger":"tls.issuance.acme.acme_client","msg":"deactivating authorization","identifier":"t.mythemeshop.com","authz":"https://acme.zerossl.com/v2/DV90/authz/fg27oHe9Gc1wHjw5r-xBOw","error":"request to https://acme.zerossl.com/v2/DV90/authz/fg27oHe9Gc1wHjw5r-xBOw failed after 1 attempts: context deadline exceeded"}
Mar 23 15:56:52 front caddy[28894]: {"level":"info","ts":1616511412.7255385,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["t.mythemeshop.com"]}
Mar 23 15:56:52 front caddy[28894]: {"level":"info","ts":1616511412.725548,"logger":"tls.obtain","msg":"releasing lock","identifier":"t.mythemeshop.com"}
Mar 23 15:56:52 front caddy[28894]: {"level":"info","ts":1616511412.8838143,"logger":"tls.on_demand","msg":"obtaining new certificate","server_name":"t.mythemeshop.com"}
Mar 23 15:56:52 front caddy[28894]: {"level":"info","ts":1616511412.8840482,"logger":"tls.obtain","msg":"acquiring lock","identifier":"t.mythemeshop.com"}
Mar 23 15:56:52 front caddy[28894]: {"level":"info","ts":1616511412.8841367,"logger":"tls.obtain","msg":"lock acquired","identifier":"t.mythemeshop.com"}
Mar 23 15:56:52 front caddy[28894]: {"level":"info","ts":1616511412.8845453,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["t.mythemeshop.com"]}
Mar 23 15:56:55 front caddy[28894]: {"level":"info","ts":1616511415.586907,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["trail.smart-brand.fr"]}
- increased issuers timeout to 180s
- increased burst rate to 100/s
- swap zerossl/letencrypt order
- registered on zerossl to manualy specify EAB
- started to dig into code of Caddy + Certmagic (as “waiting on internal rate limiter” comes from Certmagic), but codebase is a bit too much for a Go newbie like me
- googled a lot about this issue without finding any revelant info.
