Continuing the discussion from Internal CA - automatic renewal of intermediate cert:
2.4.6
I’m trying to implement this here at my home: Caddy reverse proxy + Nextcloud + Collabora + Bitwarden_rs with local HTTPS
- Docker on Raspi 4 (hostname: rowena) behind private DSL (port 80 and 443 forwarded to Pi, DynDNS etc. all working fine)
- Caddy container to be used as reverse proxy and local CA
- Nextcloud as backend service
- Caddy and Nextcloud service connected via Docker network
Goal: TLS between Frontend (reverse proxy) and backend (Nextcloud)
Please see original topic.
Sometimes(???), during certificate renewal (ACME challenge?), the Caddy CA does hand out a fresh server certificate with an outdated intermediate certificate.
Trying to connect to the backend service (Nextcloud) via the reverse proxy, I get a HTTP 502 Bad Gateway. The Proxy cannot connect to the backend service.
In the logs of the reverse proxy (frontend) I find this:
2021-12-17T12:49:48.362131078Z {
"level": "error",
"ts": 1639745388.3616397,
"logger": "http.log.error",
"msg": "x509: certificate has expired or is not yet valid: current time 2021-12-17T12:49:48Z is after 2021-12-17T00:05:59Z",
"request": {
"remote_addr": "192.168.112.1:35064",
"proto": "HTTP/1.1",
"method": "GET",
"host": "cloud.domain.net",
"uri": "/status.php",
"headers": {
"Authorization": [
"Basic cm9uOnNSWEJZLWJmREJxLUw5QzlyLThnRG5YLWpRRXlD"
"User-Agent": [
"Mozilla/5.0 (Macintosh) mirall/3.3.3git (build 7266) (Nextcloud, osx-19.6.0 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
"Accept": [
"Accept-Encoding": [
"gzip, deflate"
"X-Request-Id": [
"f6c588b6-4810-4adc-a3e2-1dda773869ff"
"Cookie": [
"__Host-nc_sameSiteCookielax=true; __Host-nc_sameSiteCookiestrict=true; oc_sessionPassphrase=djT%2BHwbwuxMQNf2tZhxhSuHesJb645xba7gJ29fkX6oCBdoTH4THe9n%2FqEuYtnSOZPr1afF0ts5iofubGXZKgpPKc6Uh7FLf48mV9itKoMOk3oaSX8VyjDuQR3dLOLba; ocgsgfzlngt6=6cec6238a0db064eecfa0b01e6dd8198"
"Connection": [
"Keep-Alive"
"Accept-Language": [
"en-DE,*"
"tls": {
"resumed": false,
"version": 772,
"cipher_suite": 4867,
"proto": "",
"proto_mutual": true,
"server_name": "cloud.domain.net"
"duration": 0.01587291,
"status": 502,
"err_id": "8gps69ehw",
"err_trace": "reverseproxy.statusError (reverseproxy.go:886)"
In the logs of the backend service (Caddy serving static Nextcloud content and forwarding to PHP-FPM):
2021-12-17T12:52:54.834094820Z {
"level": "debug",
"ts": 1639745574.8334348,
"logger": "tls.handshake",
"msg": "choosing certificate",
"identifier": "ncweb",
"num_choices": 1
2021-12-17T12:52:54.834297486Z {
"level": "debug",
"ts": 1639745574.8335903,
"msg": "default certificate selection results",
"subjects": [
"ncweb"
"managed": true,
"issuer_key": "proxy-acme-local-directory",
"hash": "bea83ae0fe0757f68dccd9b96d52e374932ffe8c1fa11464e303f4d0dd24b061"
2021-12-17T12:52:54.834363449Z {
"level": "debug",
"ts": 1639745574.833675,
"msg": "matched certificate in cache",
"subjects": [
"ncweb"
"managed": true,
"expiration": 1639772631,
2021-12-17T12:52:54.843031261Z {
"level": "debug",
"ts": 1639745574.84263,
"logger": "http.stdlib",
"msg": "http: TLS handshake error from 192.168.112.2:36548: remote error: tls: bad certificate"
I checked the certificate on the backend Caddy:
/data/caddy # ls -lsa certificates/proxy-acme-local-directory/ncweb/
total 20
4 drwx------ 2 root root 4096 Dec 10 00:23 .
4 drwx------ 3 root root 4096 Dec 10 00:23 ..
4 -rw------- 1 root root 1384 Dec 17 08:23 ncweb.crt
4 -rw------- 1 root root 130 Dec 17 08:23 ncweb.json
4 -rw------- 1 root root 227 Dec 17 08:23 ncweb.key
/data/caddy # less certificates/proxy-acme-local-directory/ncweb/ncweb.crt
-----BEGIN CERTIFICATE-----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=
-----END CERTIFICATE-----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So apparently at 8:22 this morning, the backend caddy has retrieved a new certificate from the frontend caddy
but has not received the new intermediate certificate (which at time of the renewal had been expired already). I suppose during the ACME challenge one usually receives the full cert chain, which means that the CA on the frontend caddy must have delivered the chain with the outdated intermediate certificate.
On the frontend caddy (CA), the intermediate certificate has been renewed on 15 December already:
# on frontend caddy
/data/caddy # ls -lsa pki/authorities/local/
total 24
4 drwx------ 2 root root 4096 Oct 3 18:12 .
4 drwx------ 3 root root 4096 Oct 3 18:12 ..
4 -rw------- 1 root root 676 Dec 15 14:39 intermediate.crt
4 -rw------- 1 root root 227 Dec 15 14:39 intermediate.key
4 -rw------- 1 root root 627 Oct 3 18:12 root.crt
4 -rw------- 1 root root 227 Oct 3 18:12 root.key
Don’t know if there’s anything else that I could provide from my setup.
