Intermittend 502 errors
I currently have Caddy installed as a reverse proxy towards a bunch of services. Some are hosted on a webserver (on another host which is reacheable behind the proxy), some are docker based (on yet another host).
From time to time I’m getting 502 errors in the log and timeouts, and I’m trying to figure out what or why.
At the moment of the 502 errors in Caddy the backend service is actually operation and reacheable from the proxy host, yet caddy throws an error.
I’ve reduced my config to the bare minimum but still am hitting these errors.
  "level": "error",
  "ts": 1755544865.387159,
  "logger": "http.log.error.log9",
  "msg": "dial tcp: lookup webhost.hvergelmir.internal: i/o timeout",
  "request": {
    "remote_ip": "8.29.198.26",
    "remote_port": "62168",
    "client_ip": "8.29.198.26",
    "proto": "HTTP/1.1",
    "method": "GET",
    "host": "kcore.org",
    "uri": "/feed.xml",
    "headers": {
      "Connection": [
        "close"
      "Cache-Control": [
        "no-cache"
      "Pragma": [
        "no-cache"
      "Accept": [
      "From": [
        "feeds@feedly.com"
      "User-Agent": [
        "Feedly/1.0 (+https://feedly.com/poller.html; 3 subscribers; )"
      "Accept-Encoding": [
        "gzip, compress, deflate"
    "tls": {
      "resumed": false,
      "version": 772,
      "cipher_suite": 4865,
      "proto": "",
      "server_name": "kcore.org"
  "duration": 3.001237416,
  "status": 502,
  "err_id": "b2542u2vm",
  "err_trace": "reverseproxy.statusError (reverseproxy.go:1390)"
I was originally using Caddy from the official Debian repository and it had the issue. this caddy version is recompiled with the crowdsec plugin added.
It is run from systemd.
Linux proxy 6.8.12-9-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-9 (2025-03-16T19:18Z) x86_64 GNU/Linux
Via systemd:
# caddy.service
# for your installation.
Type=notify
 level DEBUG
 output file /var/log/caddy/caddy.log
crowdsec {
  api_key "API_KEY"
kcore.org www.kcore.org {
    Permissions-Policy interest-cohort=()
    Srict-Transport-Security max-age=31536000;
    output file /var/log/caddy/kcore.org.log
  route {
    crowdsec
    reverse_proxy https://webhost.hvergelmir.internal {
        tls_insecure_skip_verify
      header_up Host {host}
Caddy seems to have a problem resolving webhost.hvergelmir.internal. If you have an internal DNS server for this domain, make sure it’s available. Or you can create an entry in your hosts file.
In the meanwhile I went digging a bit further and came across a rate limit on my internal DNS. I wasn’t expecting to hit this, but appareantely it did. So I’ve removed it and since then have no longer seen this particular problem :wink:
