I’m trying to use the layer4 module but i keep getting errors that state the service does not recognize the module. What am i doing wrong installing this custom module?
user1@sync ✔ 22:28:32 /etc/caddy > caddy run --config /etc/caddy/Caddyfile
2025/04/13 22:28:38.932 INFO using config from file {"file": "/etc/caddy/Caddyfile"}
Error: adapting config using caddyfile: /etc/caddy/Caddyfile:2: unrecognized global option: layer4
user1@sync ✘ 22:28:38 /etc/caddy >
user1@sync ✘ 22:29:13 /etc/caddy > sudo systemctl status caddy
× caddy.service - Caddy
Loaded: loaded (/etc/systemd/system/caddy.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Sun 2025-04-13 22:15:15 UTC; 14min ago
Process: 1738 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
Main PID: 1738 (code=exited, status=1/FAILURE)
CPU: 45ms
Apr 13 22:15:15 sync.maxworks.pro caddy[1738]: LOGNAME=caddy
Apr 13 22:15:15 sync.maxworks.pro caddy[1738]: USER=caddy
Apr 13 22:15:15 sync.maxworks.pro caddy[1738]: INVOCATION_ID=63e16bc4d2214c1fa024eca71e29fa44
Apr 13 22:15:15 sync.maxworks.pro caddy[1738]: JOURNAL_STREAM=8:21655
Apr 13 22:15:15 sync.maxworks.pro caddy[1738]: SYSTEMD_EXEC_PID=1738
Apr 13 22:15:15 sync.maxworks.pro caddy[1738]: {"level":"info","ts":1744582515.396744,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Apr 13 22:15:15 sync.maxworks.pro caddy[1738]: Error: adapting config using caddyfile: /etc/caddy/Caddyfile:2: unrecognized global option: l4
Apr 13 22:15:15 sync.maxworks.pro systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Apr 13 22:15:15 sync.maxworks.pro systemd[1]: caddy.service: Failed with result 'exit-code'.
Apr 13 22:15:15 sync.maxworks.pro systemd[1]: Failed to start caddy.service - Caddy.
maxb@sync ✘ 22:29:18 /etc/caddy >
After its been installed i get a ././caddy is this the correct executable?
go: added github.com/things-go/go-socks5 v0.0.5
2025/04/13 22:40:44 [INFO] exec (timeout=0s): /usr/local/go/bin/go get -v
2025/04/13 22:40:48 [INFO] Build environment ready
2025/04/13 22:40:48 [INFO] Building Caddy
2025/04/13 22:40:48 [INFO] exec (timeout=0s): /usr/local/go/bin/go mod tidy -e
2025/04/13 22:40:48 [INFO] exec (timeout=0s): /usr/local/go/bin/go build -o /etc/caddy/caddy -ldflags -w -s -trimpath -tags nobadger,nomysql,nopgx
2025/04/13 22:40:54 [INFO] Build complete: ./caddy
2025/04/13 22:40:54 [INFO] Cleaning up temporary folder: /tmp/buildenv_2025-04-13-2240.3637856850
././caddy version
maxb@sync ✘ 22:29:46 /etc/caddy > caddy version
maxb@sync ✔ 22:29:50 /etc/caddy >
Debian 12 in a VPS. I originally installed caddy using the below method
sudo apt update
sudo apt install caddy
I installed this layer4 package with xcaddy GitHub - caddyserver/xcaddy: Build Caddy with plugins · GitHub. Here is the git GitHub - mholt/caddy-l4: Layer 4 (TCP/UDP) app for Caddy · GitHub.
I installed it with the below command. I also needed to install go which I set a path variable in my zsh shell.
$ xcaddy build --with github.com/mholt/caddy-l4
i set the service file up as the efault
Type=notify
maxb@sync ✔ 22:33:47 systemd/system >
layer4 {
server {
listen :15000
route {
match tls
proxy {
to localhost:22067
