Installing links caddy
i cannot install links caddy. defender will not let me open the exe file. what am i doing wrong?
Hi @Ricardo1,
More details would be appreciated.
But how about temporarily disabling Defender.
Oh, also this should be in Help , not Coding
oops sorry i am a bit new to this stuff it took me ages to find out to reply. my problem is that i recently had some work done on my system. My Links 2003 golf game is now not working properly. my big problems is i am plagued with mouse traces. the links help suggested caddy could help.. I have tried disabling defender but know help. They (Links help) tried sending me the link in Dropbox. still cannot open getting blocked by my security stuff. apparently there is a portion of links caddy which installs Voodoo. i have downloaded the suggested file but i cannot get it to make any changes to my Links file. i have joined the Links 2003 community but cannot find how to try and get help.
Had you opened the topic in Help you would have seen this set of questions.
Type here
PASTE OVER THIS HERE IN THIS CODE BLOCK.
Please ensure it looks nice.
Paste here
Type here
Type here
Type here
sorry Bruce this is completely over my head. please treat me as a 5 year old. i have absolutely no clue as to what to do.
Kindly wait for more knowledgeable Caddy community volunteers to assist.
None of this makes sense, and I’m inclined to believe this is a troll post. There’s no way this game requires Caddy; and if caddy was ever mentioned to you in relation to the game, then it’s probably the caddy car in the game or whatever.
If you disagree, you’ll have to share more details. Be as extensive as possible. You can also ask https://gemini.google.com/
i can assure you this is a genuine plea for help. my pc has an INTEL graphics card which Lhttps://www.dropbox.com/scl/fi/kyu1qncynguw230thndjm/Links-Caddy-Setup-0.11.5.exe?rlkey=ezoizmxtpkajcv04zsozncr6v&dl=0inks dose not like. from the help in links they tried to send me this . sorry got a bit mixed up but you can see they are suggesting i open this trouble shooter which has an option for installing Voodo? which will fix the mouse trails. i am at a loss what to do.
I’m still confused. If you’re still talking about the car in the game, then you’re at the wrong place. This forum is for web server software.
i need to fix the software so it will run correctly. no mouse trails
And is the software a web server?
This community forum is for the web server software named Caddy.
What software are you specifically speaking of?
Version number would be nice as well.
http://www.linkscountryclub.com/downloads/links-caddy/Links-Caddy-Setup-0.11.4.exe this software will apparently fix my problem but i cannot open it. the exe file is noy liked. if i am in the wrong forum let me know. Thanks
Yes, it appears to me that you are at the wrong forum.
Sorry. :slightly_frowning_face:
