Increase cache entry size when using minimal cache configuration
I want to cache some GET responses for static resources. I notice that the default in-memory cache when using cache_handler plugin with minimal configuration only allows me to store entires that are up to 1MB in size. How can I configure it to store a small number of very large files (say up to 500MB) that will be downloaded often by clients. I don’t want to keep hitting backend servers for the same file and am happy to hold them in memory. My current configuration is working fine for files smaller than 1MB and the 24 hours TTL seems to be fine. So how can I support larger files?
{"level":"debug","ts":1723035465.317409,"logger":"http.handlers.cache","msg":"Incomming request &{Method:GET URL:/storage/blob/download/865EFE98955C70CC36869A6A73509D08DBECFDFA Proto:HTTP/2.0 ProtoMajor:2 ProtoMinor:0 Header:map[Accept:[text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7] Accept-Encoding:[gzip, deflate, br, zstd] Accept-Language:[en-US,en;q=0.9] Cache-Control:[max-age=0] Cookie:[REDACTED] Priority:[u=0, i] Sec-Ch-Ua:[\"Not)A;Brand\";v=\"99\", \"Google Chrome\";v=\"127\", \"Chromium\";v=\"127\"] Sec-Ch-Ua-Mobile:[?0] Sec-Ch-Ua-Platform:[\"Windows\"] Sec-Fetch-Dest:[document] Sec-Fetch-Mode:[navigate] Sec-Fetch-Site:[none] Sec-Fetch-User:[?1] Upgrade-Insecure-Requests:[1] User-Agent:[Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Safari/537.36]] Body:0xc00048e888 GetBody:<nil> ContentLength:0 TransferEncoding:[] Close:false Host:gateway.test.com Form:map[] PostForm:map[] MultipartForm:<nil> Trailer:map[] RemoteAddr:192.168.1.116:52363 RequestURI:/storage/blob/download/865EFE98955C70CC36869A6A73509D08DBECFDFA TLS:0xc000259d90 Cancel:<nil> Response:<nil> ctx:0xc0006b8a20 pat:<nil> matches:[] otherValues:map[]}"}
{"level":"debug","ts":1723035465.317409,"logger":"http.handlers.cache","msg":"Request cache-control &{MaxAge:0 MaxStale:-1 MaxStaleSet:false MinFresh:-1 NoCache:false NoStore:false NoTransform:false OnlyIfCached:false StaleIfError:0 Extensions:[]}"}
{"level":"debug","ts":1723035465.317409,"logger":"http.handlers.cache","msg":"Request the upstream server"}
{"level":"debug","ts":1723035465.317409,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"backend.test.com:443","total_upstreams":1}
{"level":"debug","ts":1723035465.317409,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"backend.test.com:443","duration":0,"request":{"remote_ip":"192.168.1.116","remote_port":"52363","client_ip":"192.168.1.116","proto":"HTTP/2.0","method":"GET","host":"gateway.test.com","uri":"/storage/blob/download/865EFE98955C70CC36869A6A73509D08DBECFDFA","headers":{"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Site":["none"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-User":["?1"],"X-Forwarded-Host":["gateway.test.com"],"Priority":["u=0, i"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Date":["Wed, 07 Aug 2024 12:57:45 UTC"],"Accept-Language":["en-US,en;q=0.9"],"Cookie":[REDACTED],"Cache-Control":["max-age=0"],"X-Forwarded-For":["192.168.1.116"],"X-Forwarded-Proto":["https"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Safari/537.36"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Mode":["navigate"],"Sec-Ch-Ua":["\"Not)A;Brand\";v=\"99\", \"Google Chrome\";v=\"127\", \"Chromium\";v=\"127\""],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"gateway.test.com"}},"headers":{"Date":["Wed, 07 Aug 2024 12:32:51 GMT"],"Age":["1494"],"Cache-Control":["public, s-maxage=86400"],"Content-Length":["27822080"],"Content-Disposition":["attachment; filename=gotham_v1.27.7.bin"],"X-Frame-Options":["SAMEORIGIN"],"Content-Security-Policy":["frame-ancestors 'self'"]},"status":200}
{"level":"debug","ts":1723035465.6802907,"logger":"http.handlers.cache","msg":"Response cache-control &{MustRevalidate:false NoCache:map[] NoCachePresent:false NoStore:false NoTransform:false Public:true Private:map[] PrivatePresent:false ProxyRevalidate:false MaxAge:-1 SMaxAge:86400 Immutable:false StaleIfError:-1 StaleWhileRevalidate:-1 Extensions:[]}"}
{"level":"debug","ts":1723035465.7239394,"logger":"http.handlers.cache","msg":"Store the response for GET-https-gateway.test.com-/storage/blob/download/865EFE98955C70CC36869A6A73509D08DBECFDFA with duration 23h59m59.3197092s"}
{"level":"error","ts":1723035465.8361752,"logger":"http.handlers.cache","msg":"Impossible to set the key GET-https-gateway.test.com-/storage/blob/download/865EFE98955C70CC36869A6A73509D08DBECFDFA into Badger, Value with size 16085847 exceeded 1048576 limit. Value:\n00000000  04 22 4d 18 64 70 b9 90  19 30 00 f6 70 48 54 54  |.\"M.dp...0..pHTT|\n00000010  50 2f 30 2e 30 20 32 30  30 20 4f 4b 0d 0a 41 67  |P/0.0 200 OK..Ag|\n00000020  65 3a 20 31 34 39 34 0d  0a 43 61 63 68 65 2d 43  |e: 1494..Cache-C|\n00000030  6f 6e 74 72 6f 6c 3a 20  70 75 62 6c 69 63 2c 20  |ontrol: public, |\n00000040  73 2d 6d 61 78 61 67 65  3d 38 36 34 30 30 0d 0a  |s-maxage=86400..|\n00000050  43 6f 6e 74 65 6e 74 2d  44 69 73 70 6f 73 69 74  |Content-Disposit|\n00000060  69 6f 6e 3a 20 61 74 74  61 63 68 6d 65 6e 74 3b  |ion: attachment;|\n00000070  20 66 69 6c 65 6e 61 6d  65 3d 67 6f 74 68 61 6d  | filename=gotham|\n00000080  5f 76 31 2e 32 37 2e 37  2e 62 69 6e 3e 00 fd 8a  |_v1.27.7.bin>...|\n00000090  53 65 63 75 72 69 74 79  2d 50 6f 6c 69 63 79 3a  |Security-Policy:|\n000000a0  20 66 72 61 6d 65 2d 61  6e 63 65 73 74 6f 72 73  | frame-ancestors|\n000000b0  20 27 73 65 6c 66 27 0d  0a 44 61 74 65 3a 20 57  | 'self'..Date: W|\n000000c0  65 64 2c 20 30 37 20 41  75 67 20 32 30 32 34 20  |ed, 07 Aug 2024 |\n000000d0  31 32 3a 33 32 3a 35 31  20 47 4d 54 0d 0a 53 65  |12:32:51 GMT..Se|\n000000e0  72 76 65 72 3a 20 43 61  64 64 79 0d 0a 58 2d 46  |rver: Caddy..X-F|\n000000f0  72 61 6d 65 2d 4f 70 74  69 6f 6e 73 3a 20 53 41  |rame-Options: SA|\n00000100  4d 45 4f 52 49 47 49 4e  0d 0a 58 2d 53 6f 75 69  |MEORIGIN..X-Soui|\n00000110  6e 2d 53 74 6f 72 65 64  2d 4c 65 6e 67 74 68 3a  |n-Stored-Length:|\n00000120  20 32 37 38 32 32 30 38  30 21 00 f3 19 54 74 6c  | 27822080!...Ttl|\n00000130  3a 20 32 34 68 30 6d 30  73 0d 0a 0d 0a 00 08 00  |: 24h0m0s.......|\n00000140  00 00 00 00 00 00 18 00  00 00 08 02 00 00 30 03  |..............0.|\n00000150  00 00 58 74 00 16 00 02  02 00 73 f0 f2 00 00 08  |..Xt......s.....|\n00000160  67 01 0e 00 0f 02 00 3b  12 11 4e 00 f2 01 18 02  |g......;..N.....|\n00000170  02 00 60 2b 03 00 04 51  74 00 04 e9 f2 00 16 00  |..`+...Qt.......|\n00000180  03 02 00 6f 01 67 01 00  81 a8 80 00 42 42 bd 9f  |...o.g......BB..|\n00000190  21 33 04 01 17 04 04 00  13 90 04 00 08 02 00 53  |!3.............S|\n000001a0  a0 00 00 00 48 10 00 13  90 08 00 52 00 00 00 00  |....H......R....|\n000001b0  60 07 00 23 00 00 40 00  04 51 01 0f 02 00 17 2e  |`..#..@..Q......|\n000001c0  e8 03 04 00 0f 02 00 01  53 6a 02 00 00 18 ab 01  |........Sj......|\n000001d0  04 08 00 0f 02 00 01 08  28 00 13 05 04 00 0f 02  |........(.......|\n000001e0  00 01 17 10 04 00 0f 02  00 09 ff 1e 72 74 73 70  |............rtsp|\n000001f0  5f 61 75 74 6f 73 74 6f  70 3d 64 69 73 61 62 6c  |_autostop=disabl|\n00000200  65 20 73 65 63 5f 73 74  72 65 61 6d 5f 73 69 7a  |e sec_stream_siz|\n00000210  65 3d 37 32 30 78 34 30  30 48 00 08 0f 02 00 ff  |e=720x400H......|\n00000220  ff ff ff ff 86 c2 89 10  be 3d 03 00 01 00 0f 06  |.........=......|\n00000230  e7 07 08 07 af 00 00 01  00 00 00 90 eb 24 a3 71  |.............$.q|\n00000240  07 42 0f 02 00 7c f5 3a  cb 00 00 ea 61 37 6c 00  |.B...|.:....a7l.|\n00000250  00 00 00 00 43 4b 03 00  d4 30 00 00 95 01 08 00  |....CK...0......|\n00000260  a3 48 b8 48 7a 56 ff 01  a3 00 00 00 88 13 00 00  |.H.HzV..........|\n00000270  01 00 3f 01 21 15 00 01  02 00 01 01 00 00 02 01  |..?.!...........|\n00000280  00 00 03 01 02 00 03 01  40 00 00 00 31 00 02 00  |........@...1...|\n00000290  26 68 07 95 10 1b 00 00  71 3f 00 83 06 e9 00 22  |&h......q?.....\"|\n000002a0  20 20 04 00 a2 31 45 07  00 31 45 07 00 11 3b 04  |  ...1E..1E...;.|\n000002b0  00 d2 00 00 e5 12 00 01  00 00 02 00 00 00 e4 2e  |................|\n000002c0  00 93 c0 00 00 00 00 00  e0 00 70 9b 07 04 02 00  |..........p.....|\n000002d0  23 c0 00 60 00 13 11 19  00 22 03 00 38 00 9f 00  |#..`.....\"..8...|\n000002e0  01 28 05 01 00 00 00 20  01 00 04 83 00 00 01 c0  |.(..... ........|\n000002f0  78 56 34 12 48 00 23 00  50 08 00 04 02 00 f2 ff  |xV4.H.#.P.......|\n00000300  3c 01 00 00 00 07 00 00  00 00 11 11 12 f2 46 6d  |<.............Fm|\n00000310  48 85 46 20 98 00 28 1a  d0 6b 48 06 68 04 25 2e  |H.F ..(..kH.h.%.|\n00000320  40 21 98 22 9a d1 43 01  23 c3 62 83 69 0b 40 83  |@!.\"..C.#.b.i.@.|\n00000330  61 83 6a 13 43 83 62 43  68 13 43 43 60 03 68 0b  |a.j.C.bCh.CC`.h.|\n00000340  40 00 2e 00 d1 13 43 03  60 00 23 db 43 43 62 5f  |@.....C.`.#.CCb_|\n00000350  4b 01 3b 00 2b fc d1 5e  48 36 9f 07 60 5d 4d 37  |K.;.+..^H6..`]M7|\n00000360  9e 38 9f 00 f0 d5 f8 10  99 dc 22 a9 50 11 99 5a  |.8........\".P..Z|\n00000370  4a a9 50 12 99 59 4a a9  50 10 99 01 23 19 43 dc  |J.P..YJ.P...#.C.|\n00000380  22 a9 50 db 43 19 40 a9  50 26 99 00 29 05 d0 54  |\".P.C.@.P&..)..T|\n00000390  4a 54 49 a9 50 50 22 54  49 a9 50 13 99 90 22 a9  |JTI.PP\"TI.P...\".|\n000003a0  50 14 99 94 22 a9 50 15  99 f0 22 a9 50 16 99 f4  |P...\".P...\".P...|\n000003b0  22 a9 50 17 99 4d 4a a9  50 18 99 4d 4a a9 50 19  |\".P..MJ.P..MJ.P.|\n000003c0  99 4c 4a a9 50 1a 99 4c  4a a9 50 1b 99 4b 4a a9  |.LJ.P..LJ.P..KJ.|\n000003d0  50 2c 22 20 23 00 21 4a  4a a9 50 3e 4d 6e 6b 80  |P,\" #.!JJ.P>Mnk.|\n000003e0  21 0e 40 f6 09 47 4d 01  21 69 60 00 21 69 60 38  |!.@..GM.!i`.!i`8|\n000003f0  48 05 99 00 f0 8f f8 1f  99 c1 62 01 99 41 60 02  |H.........b..A`.|\n"}
{"level":"error","ts":1723035465.8361752,"logger":"http.handlers.cache","msg":"Impossible to set value into Badger, Value with size 16085847 exceeded 1048576 limit. Value:\n00000000  04 22 4d 18 64 70 b9 90  19 30 00 f6 70 48 54 54  |.\"M.dp...0..pHTT|\n00000010  50 2f 30 2e 30 20 32 30  30 20 4f 4b 0d 0a 41 67  |P/0.0 200 OK..Ag|\n00000020  65 3a 20 31 34 39 34 0d  0a 43 61 63 68 65 2d 43  |e: 1494..Cache-C|\n00000030  6f 6e 74 72 6f 6c 3a 20  70 75 62 6c 69 63 2c 20  |ontrol: public, |\n00000040  73 2d 6d 61 78 61 67 65  3d 38 36 34 30 30 0d 0a  |s-maxage=86400..|\n00000050  43 6f 6e 74 65 6e 74 2d  44 69 73 70 6f 73 69 74  |Content-Disposit|\n00000060  69 6f 6e 3a 20 61 74 74  61 63 68 6d 65 6e 74 3b  |ion: attachment;|\n00000070  20 66 69 6c 65 6e 61 6d  65 3d 67 6f 74 68 61 6d  | filename=gotham|\n00000080  5f 76 31 2e 32 37 2e 37  2e 62 69 6e 3e 00 fd 8a  |_v1.27.7.bin>...|\n00000090  53 65 63 75 72 69 74 79  2d 50 6f 6c 69 63 79 3a  |Security-Policy:|\n000000a0  20 66 72 61 6d 65 2d 61  6e 63 65 73 74 6f 72 73  | frame-ancestors|\n000000b0  20 27 73 65 6c 66 27 0d  0a 44 61 74 65 3a 20 57  | 'self'..Date: W|\n000000c0  65 64 2c 20 30 37 20 41  75 67 20 32 30 32 34 20  |ed, 07 Aug 2024 |\n000000d0  31 32 3a 33 32 3a 35 31  20 47 4d 54 0d 0a 53 65  |12:32:51 GMT..Se|\n000000e0  72 76 65 72 3a 20 43 61  64 64 79 0d 0a 58 2d 46  |rver: Caddy..X-F|\n000000f0  72 61 6d 65 2d 4f 70 74  69 6f 6e 73 3a 20 53 41  |rame-Options: SA|\n00000100  4d 45 4f 52 49 47 49 4e  0d 0a 58 2d 53 6f 75 69  |MEORIGIN..X-Soui|\n00000110  6e 2d 53 74 6f 72 65 64  2d 4c 65 6e 67 74 68 3a  |n-Stored-Length:|\n00000120  20 32 37 38 32 32 30 38  30 21 00 f3 19 54 74 6c  | 27822080!...Ttl|\n00000130  3a 20 32 34 68 30 6d 30  73 0d 0a 0d 0a 00 08 00  |: 24h0m0s.......|\n00000140  00 00 00 00 00 00 18 00  00 00 08 02 00 00 30 03  |..............0.|\n00000150  00 00 58 74 00 16 00 02  02 00 73 f0 f2 00 00 08  |..Xt......s.....|\n00000160  67 01 0e 00 0f 02 00 3b  12 11 4e 00 f2 01 18 02  |g......;..N.....|\n00000170  02 00 60 2b 03 00 04 51  74 00 04 e9 f2 00 16 00  |..`+...Qt.......|\n00000180  03 02 00 6f 01 67 01 00  81 a8 80 00 42 42 bd 9f  |...o.g......BB..|\n00000190  21 33 04 01 17 04 04 00  13 90 04 00 08 02 00 53  |!3.............S|\n000001a0  a0 00 00 00 48 10 00 13  90 08 00 52 00 00 00 00  |....H......R....|\n000001b0  60 07 00 23 00 00 40 00  04 51 01 0f 02 00 17 2e  |`..#..@..Q......|\n000001c0  e8 03 04 00 0f 02 00 01  53 6a 02 00 00 18 ab 01  |........Sj......|\n000001d0  04 08 00 0f 02 00 01 08  28 00 13 05 04 00 0f 02  |........(.......|\n000001e0  00 01 17 10 04 00 0f 02  00 09 ff 1e 72 74 73 70  |............rtsp|\n000001f0  5f 61 75 74 6f 73 74 6f  70 3d 64 69 73 61 62 6c  |_autostop=disabl|\n00000200  65 20 73 65 63 5f 73 74  72 65 61 6d 5f 73 69 7a  |e sec_stream_siz|\n00000210  65 3d 37 32 30 78 34 30  30 48 00 08 0f 02 00 ff  |e=720x400H......|\n00000220  ff ff ff ff 86 c2 89 10  be 3d 03 00 01 00 0f 06  |.........=......|\n00000230  e7 07 08 07 af 00 00 01  00 00 00 90 eb 24 a3 71  |.............$.q|\n00000240  07 42 0f 02 00 7c f5 3a  cb 00 00 ea 61 37 6c 00  |.B...|.:....a7l.|\n00000250  00 00 00 00 43 4b 03 00  d4 30 00 00 95 01 08 00  |....CK...0......|\n00000260  a3 48 b8 48 7a 56 ff 01  a3 00 00 00 88 13 00 00  |.H.HzV..........|\n00000270  01 00 3f 01 21 15 00 01  02 00 01 01 00 00 02 01  |..?.!...........|\n00000280  00 00 03 01 02 00 03 01  40 00 00 00 31 00 02 00  |........@...1...|\n00000290  26 68 07 95 10 1b 00 00  71 3f 00 83 06 e9 00 22  |&h......q?.....\"|\n000002a0  20 20 04 00 a2 31 45 07  00 31 45 07 00 11 3b 04  |  ...1E..1E...;.|\n000002b0  00 d2 00 00 e5 12 00 01  00 00 02 00 00 00 e4 2e  |................|\n000002c0  00 93 c0 00 00 00 00 00  e0 00 70 9b 07 04 02 00  |..........p.....|\n000002d0  23 c0 00 60 00 13 11 19  00 22 03 00 38 00 9f 00  |#..`.....\"..8...|\n000002e0  01 28 05 01 00 00 00 20  01 00 04 83 00 00 01 c0  |.(..... ........|\n000002f0  78 56 34 12 48 00 23 00  50 08 00 04 02 00 f2 ff  |xV4.H.#.P.......|\n00000300  3c 01 00 00 00 07 00 00  00 00 11 11 12 f2 46 6d  |<.............Fm|\n00000310  48 85 46 20 98 00 28 1a  d0 6b 48 06 68 04 25 2e  |H.F ..(..kH.h.%.|\n00000320  40 21 98 22 9a d1 43 01  23 c3 62 83 69 0b 40 83  |@!.\"..C.#.b.i.@.|\n00000330  61 83 6a 13 43 83 62 43  68 13 43 43 60 03 68 0b  |a.j.C.bCh.CC`.h.|\n00000340  40 00 2e 00 d1 13 43 03  60 00 23 db 43 43 62 5f  |@.....C.`.#.CCb_|\n00000350  4b 01 3b 00 2b fc d1 5e  48 36 9f 07 60 5d 4d 37  |K.;.+..^H6..`]M7|\n00000360  9e 38 9f 00 f0 d5 f8 10  99 dc 22 a9 50 11 99 5a  |.8........\".P..Z|\n00000370  4a a9 50 12 99 59 4a a9  50 10 99 01 23 19 43 dc  |J.P..YJ.P...#.C.|\n00000380  22 a9 50 db 43 19 40 a9  50 26 99 00 29 05 d0 54  |\".P.C.@.P&..)..T|\n00000390  4a 54 49 a9 50 50 22 54  49 a9 50 13 99 90 22 a9  |JTI.PP\"TI.P...\".|\n000003a0  50 14 99 94 22 a9 50 15  99 f0 22 a9 50 16 99 f4  |P...\".P...\".P...|\n000003b0  22 a9 50 17 99 4d 4a a9  50 18 99 4d 4a a9 50 19  |\".P..MJ.P..MJ.P.|\n000003c0  99 4c 4a a9 50 1a 99 4c  4a a9 50 1b 99 4b 4a a9  |.LJ.P..LJ.P..KJ.|\n000003d0  50 2c 22 20 23 00 21 4a  4a a9 50 3e 4d 6e 6b 80  |P,\" #.!JJ.P>Mnk.|\n000003e0  21 0e 40 f6 09 47 4d 01  21 69 60 00 21 69 60 38  |!.@..GM.!i`.!i`8|\n000003f0  48 05 99 00 f0 8f f8 1f  99 c1 62 01 99 41 60 02  |H.........b..A`.|\n"}
Windows 11 with Caddy running natively.
caddy_windows_amd64_custom.exe run
N/A
	cache
:443 {
	# Use your own wildcard certificate with relative paths
	tls ./certs/certificate.crt ./certs/privatekey.key
	@devicefirmware path *storage/blob/download/*
	cache @devicefirmware {
		ttl 86400s
	reverse_proxy {
		to https://backend.test.com
		# Load Balancing
		lb_policy least_conn
		# Active Health checks
		health_uri /ping
		health_interval 30s
Which of the cache_handler plugin are you using? Is there any other configuration you have related to the cache?
Update: I think you are using GitHub - caddyserver/cache-handler: Distributed HTTP caching module for Caddy which uses Badger backend by default (which can be seen in your log). This has a 1MiB limit.
I decided to use xcaddy build --with github.com/caddyserver/cache-handler and switched to Redis backend. This seems to have no problems storing larger files - tested with a few 50MB video files.
There are still some questions:
  • How to limit how large objects that should be stored.
  • Limit maximum cache size (the sum of all cached objects)
  • Redis can use expiring keys, but cache_handler is not setting a ttl on the keys. (See error below)
  • What happens if Redis is used with auto-eviction?
  • What hapoens if Redis maxmemory is reached?
{"level":"error","ts":1723070468.4703934,"logger":"http.handlers.cache","msg":"Impossible to set value into Redis, invalid expire time in 'set' command"}
Thanks for the quick response. Yes I believe it’s badger by default. I really didn’t want to have any additional service requirements so was happy to cache in Badger rather than use something like Redis. I read somewhere that badger doesn’t impose size limits on items in the cache. Not sure if 1MB is a default configuration within the cache or Caddy that can be changed? I’d much prefer that as a solution. Does anyone know if I can override this 1MB size limit in either Caddyfile or JSON file?
I found this ticket Impossible to set value into Badger, Value with size 1048681 exceeded 1048576 limit · Issue #84 · caddyserver/cache-handler · GitHub but no resolution so far.
Hello there, Badger is not the recommended backend storage. It’s better to use nutsdb instead, that can handle larger payload.
By the way, for your information, in the next version of the cache-handler/souin you’ll be able to include only needed storages using --with in your building command (using xcaddy).
To limit the size that can be stored per entry, you can use the max_body_bytes directive.
I think you can limit the cache size in each provider configuration.
The redis error has been patched but not already released.
If redis (or any other that can auto evict) is used with auto-eviction, keys won’t be found so it will result as a cache miss.
If redis maxmemory is reached will be your problem because I can’t detect that on the client side :confused: .
Thank you for asking your questions @Forza I appreciate that. :slight_smile:
Thanks for your reply. Do you happen to have a reference configuration for a basic in memory nutsdb cache in caddy file or json please?
@darkweak thanks for the answers. I split out my questions so to not take over from the original topic. Hope that’s OK. Caddy cache_handler object and memory limits
