As a service on Ubuntu
Ubuntu 18.04
caddy reload ./Caddyfile
paste full file contents here
# domain name.
:80
root * /opt/ivt/apps/6.0.0/packages/client/spa
file_server * {
root /opt/ivt/apps/6.0.0/packages/client/spa
file_server * {
root /opt/ivt/photography
# php_fastcgi localhost:9000
# This is pointing to Let's Encrypt Staging environment (for dev)
# https://letsencrypt.org/docs/staging-environment/
# This will allow you to get things right before issuing trusted
# certificates and reduce the chance of your running up against rate limits.
# causes all certificates to be issued internally by default,
# rather than through a (public) ACME CA such as Let's Encrypt.
# This is useful in development environments.
local_certs
# configure automatic HTTPS. It can either disable it entirely (off)
# or disable only HTTP-to-HTTPS redirects (disable_redirects).
auto_https
(header_options) {
header_up Access-Control-Allow-Origin *
header_up Access-Control-Allow-Credentials true
header_up Access-Control-Allow-Headers Cache-Control,Content-Type
localhost {
route /weather/* {
uri replace /weather /socket.io
reverse_proxy * http://localhost:3010 {
import header_options
route /ptz/* {
uri replace /ptz /socket.io
reverse_proxy * http://localhost:3006 {
route /liveview/* {
uri replace /liveview /socket.io
reverse_proxy * http://localhost:3004 {
route /archive/* {
uri replace /archive /socket.io
reverse_proxy * http://localhost:3003 {
route /alarms/* {
uri replace /alarms /socket.io
reverse_proxy * http://localhost:3002 {
route /console_socket/* {
uri replace /console_socket /console/socket.io
reverse_proxy * http://localhost:3001 {
route /web_app_socket/* {
uri replace /web_app_socket /web/socket.io
route /api/* {
Previously, back in April when I was investigating Caddy, we came up with using some snippets (here: Need help converting NGINX config - #21 by francislavoie).
Now, I get the following error:
run: adapting config using caddyfile: ./Caddyfile:60 - Error during parsing: File to import not found: header_options
I have tried using my original file that worked previously. The above Caddyfile is just a continuing effort to get static files also served.
