Import <args> slicing not working
I am trying to use snippet + import to simplify my Caddyfile. I use wildcard certificate, so based on what I have read, I need to use handle. I found in the forums an example.
I am testing it out with respond, and respond works as expected when I
(sub) {
        @sub-{args[0]} host {args[0]}.{$HOSTNAME}
        handle @sub-{args[0]} {
                respond "{args[0]} {args[1]} {args[:]}"
Test import:
*.example.com {
    import sub heartbeat Caddy is up - subsnippet
returns heartbeat Caddy {args[:]}
According to the docs import (Caddyfile directive) — Caddy Documentation
{args[:]} should return all the arguments from version 2.7.0, but it does not work for me.
I have tried different slicings, but every time I use :, it does not parse. What am I doing wrong?
/srv # caddy -v
Docker inside Debian 12 VM on Proxmox host. Geekom A5 computer.
Dockerfile
FROM caddy:2.7.6-builder AS builder
RUN xcaddy build \
    --with github.com/caddy-dns/duckdns
FROM caddy:2.7.6
docker-compose
    # image: caddy:2
    # building own caddy to include duckdns
    build:
      context: ./build/caddy
      network: host
      - 443:443
      HOSTNAME: $DOMAIN
      TZ: $TZ
      - ./build/caddy/Caddyfile:/etc/caddy/Caddyfile
      - ./secrets/caddy/data:/data
      - ./secrets/caddy/config:/config
see above
I will add a working config file later if needed.
A current limitation is that variadic style args can only be used as a single token, and not within another token. That’s because it may expand to multiple tokens.
If you need to use space-separated string inside another, then wrap it with quotes on your import line then use {args[2]} or whatever instead.
