I/o timeout (error 502) when using Caddy for Nextcloud
I am trying to set up Caddy to work with my Nextcloud AIO containers. I followed the reverse proxy step on the Nextcloud AIO Github page. The main difference is that I do not want / cannot use the network_mode:"host" flag for Caddy. I want to portforward the Caddy container, because my OpenMediavault Dashboard is already at ports 443 and 80, and I want to keep it that way. (My router is correctly set up so that 443 and 80 direct to the Caddy Container via 446 and 82).
When I try to go to cloud.domain.tld I only see a blank page.
curl -vL
* Host cloud.domain.tld:80 was resolved.
* IPv6: (none)
* IPv4: <public_ip>
*   Trying <public_ip>:80...
* Connected to cloud.domain.tld (<public_ip>) port 80
> GET / HTTP/1.1
> Host: cloud.domain.tld
> User-Agent: curl/8.5.0
< Connection: close
< Location: https://cloud.domain.tld/
< Server: Caddy
< Date: Sun, 10 Dec 2023 00:44:35 GMT
< Content-Length: 0
* Closing connection
* Issue another request to this URL: 'https://cloud.domain.tld/'
* Host cloud.domain.tld:443 was resolved.
* IPv6: (none)
* IPv4: <public_ip>
*   Trying <public_ip>:443...
* Connected to cloud.domain.tld (<public_ip>) port 443
*  CApath: none
* SSL connection using TLSv1.3 / TLS_AES_128_GCM_SHA256 / X25519 / id-ecPublicKey
* ALPN: server accepted h2
*  subject: CN=cloud.domain.tld
*  start date: Dec  9 00:00:00 2023 GMT
*  expire date: Mar  8 23:59:59 2024 GMT
*  subjectAltName: host "cloud.domain.tld" matched cert's "cloud.domain.tld"
*  issuer: C=AT; O=ZeroSSL; CN=ZeroSSL ECC Domain Secure Site CA
*   Certificate level 0: Public key type EC/prime256v1 (256/128 Bits/secBits), signed using ecdsa-with-SHA384
*   Certificate level 1: Public key type EC/secp384r1 (384/192 Bits/secBits), signed using ecdsa-with-SHA384
*   Certificate level 2: Public key type EC/secp384r1 (384/192 Bits/secBits), signed using ecdsa-with-SHA384
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://cloud.domain.tld/
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:authority: cloud.domain.tld]
* [HTTP/2] [1] [:path: /]
* [HTTP/2] [1] [user-agent: curl/8.5.0]
* [HTTP/2] [1] [accept: */*]
> GET / HTTP/2
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Sun, 10 Dec 2023 00:44:38 GMT
* Connection #1 to host cloud.domain.tld left intact
2023-12-10T00:49:38.661648167Z INF ts=1702169378.661579 logger=admin.api msg=load complete
2023-12-10T00:49:38.661855426Z INF ts=1702169378.661789 logger=docker-proxy msg=Successfully configured server=localhost
2023-12-10T00:49:38.664143325Z WRN ts=1702169378.6640377 logger=tls msg=storage cleaning happened too recently; skipping for now storage=FileStorage:/data/caddy instance=da072402-e811-4ae4-b924-9a0b595e1971 try_again=1702255778.6640358 try_again_in=86399.999999518
2023-12-10T00:49:38.664193534Z INF ts=1702169378.6641328 logger=tls msg=finished cleaning storage units
2023-12-10T00:49:38.665954435Z INF ts=1702169378.6659122 logger=admin msg=stopped previous server address=localhost:2019
2023-12-10T00:49:45.945934227Z DBG ts=1702169385.9456952 logger=events msg=event name=tls_get_certificate id=1c406831-e5b2-41d8-9f34-57a447c92670 origin=tls data={"client_hello":{"CipherSuites":[4865,4866,4867,49195,49196,52393,49199,49200,52392,49171,49172,156,157,47,53],"ServerName":"cloud.domain.tld","SupportedCurves":[29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"<public_ip>","Port":40384,"Zone":""},"LocalAddr":{"IP":"172.30.0.3","Port":443,"Zone":""}}}
2023-12-10T00:49:45.945998614Z DBG ts=1702169385.9458342 logger=tls.handshake msg=choosing certificate identifier=cloud.domain.tld num_choices=1
2023-12-10T00:49:45.946005010Z DBG ts=1702169385.945848 logger=tls.handshake msg=default certificate selection results identifier=cloud.domain.tld subjects=["cloud.domain.tld"] managed=true issuer_key=acme.zerossl.com-v2-DV90 hash=cda353077f262f3f98bab1589a00c304e33641e57c5f033d41f805b5ba73a6fe
2023-12-10T00:49:45.946009998Z DBG ts=1702169385.945865 logger=tls.handshake msg=matched certificate in cache remote_ip=<public_ip> remote_port=40384 subjects=["cloud.domain.tld"] managed=true expiration=1709942400 hash=cda353077f262f3f98bab1589a00c304e33641e57c5f033d41f805b5ba73a6fe
2023-12-10T00:49:46.025261465Z DBG ts=1702169386.0251641 logger=http.handlers.reverse_proxy msg=selected upstream dial=host.docker.internal:11000 total_upstreams=1
2023-12-10T00:49:49.025788750Z DBG ts=1702169389.0256371 logger=http.handlers.reverse_proxy msg=upstream roundtrip upstream=host.docker.internal:11000 duration=3.000423143 request={"remote_ip":"<public_ip>","remote_port":"40384","client_ip":"<public_ip>","proto":"HTTP/2.0","method":"GET","host":"cloud.domain.tld","uri":"/index.php/204","headers":{"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["cloud.domain.tld"],"User-Agent":["Mozilla/5.0 (Android) Nextcloud-android/3.25.0"],"Http.protocol.single-Cookie-Header":["true"],"Accept-Encoding":["gzip"],"X-Forwarded-For":["<public_ip>"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"cloud.domain.tld"}} error=dial tcp 172.17.0.1:11000: i/o timeout
2023-12-10T00:49:49.025821483Z ERR ts=1702169389.0257056 logger=http.log.error msg=dial tcp 172.17.0.1:11000: i/o timeout request={"remote_ip":"<public_ip>","remote_port":"40384","client_ip":"<public_ip>","proto":"HTTP/2.0","method":"GET","host":"cloud.domain.tld","uri":"/index.php/204","headers":{"Http.protocol.single-Cookie-Header":["true"],"Accept-Encoding":["gzip"],"User-Agent":["Mozilla/5.0 (Android) Nextcloud-android/3.25.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"cloud.domain.tld"}} duration=3.000559159 status=502 err_id=cjv128dtj err_trace=reverseproxy.statusError (reverseproxy.go:1267)
2023-12-10T00:49:51.284805633Z DBG ts=1702169391.2847419 logger=http.stdlib msg=http: TLS handshake error from <public_ip>:49758: EOF
2023-12-10T00:49:53.773156867Z DBG ts=1702169393.7729933 logger=events msg=event name=tls_get_certificate id=16340c7f-6934-468b-a59e-87097ab02592 origin=tls data={"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,173,171,52398,52397,52396,157,169,52395,172,170,156,168,61,60,49208,49206,183,179,149,145,53,175,141,49207,49205,182,178,148,144,47,174,140,255],"ServerName":"cloud.domain.tld","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":null,"SupportedVersions":[772,771],"RemoteAddr":{"IP":"<public_ip>","Port":54986,"Zone":""},"LocalAddr":{"IP":"172.30.0.3","Port":443,"Zone":""}}}
2023-12-10T00:49:53.773230387Z DBG ts=1702169393.773056 logger=tls.handshake msg=choosing certificate identifier=cloud.domain.tld num_choices=1
2023-12-10T00:49:53.773236129Z DBG ts=1702169393.7730777 logger=tls.handshake msg=default certificate selection results identifier=cloud.domain.tld subjects=["cloud.domain.tld"] managed=true issuer_key=acme.zerossl.com-v2-DV90 hash=cda353077f262f3f98bab1589a00c304e33641e57c5f033d41f805b5ba73a6fe
2023-12-10T00:49:53.773241018Z DBG ts=1702169393.7730937 logger=tls.handshake msg=matched certificate in cache remote_ip=<public_ip> remote_port=54986 subjects=["cloud.domain.tld"] managed=true expiration=1709942400 hash=cda353077f262f3f98bab1589a00c304e33641e57c5f033d41f805b5ba73a6fe
2023-12-10T00:49:53.825660575Z DBG ts=1702169393.8255477 logger=http.handlers.reverse_proxy msg=selected upstream dial=host.docker.internal:11000 total_upstreams=1
2023-12-10T00:49:55.102546432Z DBG ts=1702169395.1024628 logger=docker-proxy msg=Skipping swarm config caddyfiles because swarm is not available
2023-12-10T00:49:55.120535102Z DBG ts=1702169395.1204531 logger=docker-proxy msg=Skipping swarm services because swarm is not available
2023-12-10T00:49:59.768499429Z DBG ts=1702169399.768357 logger=events msg=event name=tls_get_certificate id=16ca63c0-ae7d-4d84-93ff-2e712543f48f origin=tls data={"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,163,159,52393,52392,52394,49327,49325,49315,49311,49245,49249,49239,49235,49188,49192,107,106,49267,49271,196,195,49162,49172,57,56,136,135,157,49313,49309,49233,61,192,53,132,49195,49199,162,158,49326,49324,49314,49310,49244,49248,49238,49234,49187,49191,103,64,49266,49270,190,189,49161,49171,51,50,154,153,69,68,156,49312,49308,49232,60,186,47,150,65,255],"ServerName":"cloud.domain.tld","SupportedCurves":[30,29,25,24,23,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":null,"SupportedVersions":[772,771],"RemoteAddr":{"IP":"<public_ip>","Port":60052,"Zone":""},"LocalAddr":{"IP":"172.30.0.3","Port":443,"Zone":""}}}
2023-12-10T00:49:59.768556217Z DBG ts=1702169399.7684212 logger=tls.handshake msg=choosing certificate identifier=cloud.domain.tld num_choices=1
2023-12-10T00:49:59.768565708Z DBG ts=1702169399.768435 logger=tls.handshake msg=default certificate selection results identifier=cloud.domain.tld subjects=["cloud.domain.tld"] managed=true issuer_key=acme.zerossl.com-v2-DV90 hash=cda353077f262f3f98bab1589a00c304e33641e57c5f033d41f805b5ba73a6fe
2023-12-10T00:49:59.768574791Z DBG ts=1702169399.7684433 logger=tls.handshake msg=matched certificate in cache remote_ip=<public_ip> remote_port=60052 subjects=["cloud.domain.tld"] managed=true expiration=1709942400 hash=cda353077f262f3f98bab1589a00c304e33641e57c5f033d41f805b5ba73a6fe
2023-12-10T00:49:59.773494289Z DBG ts=1702169399.7734313 logger=http.handlers.reverse_proxy msg=selected upstream dial=host.docker.internal:11000 total_upstreams=1
2023-12-10T00:50:02.774064189Z DBG ts=1702169402.7739825 logger=http.handlers.reverse_proxy msg=upstream roundtrip upstream=host.docker.internal:11000 duration=3.000514953 request={"remote_ip":"<public_ip>","remote_port":"60052","client_ip":"<public_ip>","proto":"HTTP/1.1","method":"GET","host":"cloud.domain.tld","uri":"/apps/richdocuments/settings/fonts.json","headers":{"Date":["Sun, 10 Dec 2023 00:49:59"],"User-Agent":["COOLWSD HTTP Agent 23.05.5.4"],"X-Forwarded-For":["<public_ip>"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["cloud.domain.tld"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"cloud.domain.tld"}} error=dial tcp 172.17.0.1:11000: i/o timeout
2023-12-10T00:50:02.774103710Z ERR ts=1702169402.7740517 logger=http.log.error msg=dial tcp 172.17.0.1:11000: i/o timeout request={"remote_ip":"<public_ip>","remote_port":"60052","client_ip":"<public_ip>","proto":"HTTP/1.1","method":"GET","host":"cloud.domain.tld","uri":"/apps/richdocuments/settings/fonts.json","headers":{"User-Agent":["COOLWSD HTTP Agent 23.05.5.4"],"Date":["Sun, 10 Dec 2023 00:49:59"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"cloud.domain.tld"}} duration=3.000625293 status=502 err_id=bmugv5jfj err_trace=reverseproxy.statusError (reverseproxy.go:1267)
2023-12-10T00:50:20.039739328Z DBG ts=1702169420.0395806 logger=events msg=event name=tls_get_certificate id=b644bac6-783d-4f6c-a9f9-2c678dbd4b17 origin=tls data={"client_hello":{"CipherSuites":[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],"ServerName":"cloud.domain.tld","SupportedCurves":[29,23,24,25,256,257],"SupportedPoints":"AA==","SignatureSchemes":[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"<public_ip>","Port":60328,"Zone":""},"LocalAddr":{"IP":"172.30.0.3","Port":443,"Zone":""}}}
2023-12-10T00:50:20.039779281Z DBG ts=1702169420.0396478 logger=tls.handshake msg=choosing certificate identifier=cloud.domain.tld num_choices=1
2023-12-10T00:50:20.039788157Z DBG ts=1702169420.0396721 logger=tls.handshake msg=default certificate selection results identifier=cloud.domain.tld subjects=["cloud.domain.tld"] managed=true issuer_key=acme.zerossl.com-v2-DV90 hash=cda353077f262f3f98bab1589a00c304e33641e57c5f033d41f805b5ba73a6fe
2023-12-10T00:50:20.039796763Z DBG ts=1702169420.039689 logger=tls.handshake msg=matched certificate in cache remote_ip=<public_ip> remote_port=60328 subjects=["cloud.domain.tld"] managed=true expiration=1709942400 hash=cda353077f262f3f98bab1589a00c304e33641e57c5f033d41f805b5ba73a6fe
2023-12-10T00:50:20.061597710Z DBG ts=1702169420.0615163 logger=http.handlers.reverse_proxy msg=selected upstream dial=host.docker.internal:11000 total_upstreams=1
2023-12-10T00:50:21.382955373Z DBG ts=1702169421.3828876 logger=http.stdlib msg=http: TLS handshake error from <public_ip>:46354: EOF
Docker
OpenMediaVault: 6.9.9-1 (Shaitan)
Kernel: Linux 6.1.0-0.deb11.11-amd64
Dockerfile
FROM caddy:builder AS builder
RUN xcaddy build \
    --with github.com/lucaslorentz/caddy-docker-proxy/v2 \
FROM caddy:alpine
CMD ["caddy", "docker-proxy"]
docker-compose
  # Nextcloud
  nextcloud-aio-mastercontainer:
    image: nextcloud/all-in-one:latest
    init: true
    restart: always
    container_name: nextcloud-aio-mastercontainer
      - nextcloud_aio_mastercontainer:/mnt/docker-aio-config
      - APACHE_PORT=11000
      - APACHE_IP_BINDING=0.0.0.0
      - SKIP_DOMAIN_VALIDATION=true
      - caddy
    image: caddy-docker-proxy-cloudflare-dns
    restart: always
    - CADDY_DOCKER_CADDYFILE_PATH=/etc/caddy/Caddyfile
      - 446:443
      - caddy
      - ${APPDATA}/Caddy/Caddyfile:/etc/caddy/Caddyfile
    extra_hosts: ["host.docker.internal:host-gateway"]
    external: true
  caddy_data: {}
Caddyfile
  # Email
  email <email>
  # Debug
(cloudflare) {
     dns cloudflare <api_token>
https://cloud.domain.tld:443 {
  import cloudflare
  reverse_proxy host.docker.internal:11000 {
                tls_insecure_skip_verify
My DNS is hosted at Cloudflare but I turned off the proxy,
Here are some sources I found trying to fix the issue:
This url made me add the tls_insecure_skip_verify line to the caddyfile.
Not sure where the problem lies, I also posted on the Nextcloud forum. To no avail up until now.
Use reverse_proxy nextcloud:8080 instead. This will have Caddy connect to Nextcloud through the Docker network.
You can remove the transport stuff as well, you’ll be proxying over HTTP.
port 8080 of the nextcloud container is for the AIO interface, not for the Nextcloud instance.
That is why I set the port to 11000:
See
Then just do reverse_proxy nextcloud:11000
Alright I tried a couple of things.
creates a number of containers.
nextcloud-aio-apache with ip-address 192.168.96.10 and published ports 11000:11000
nextcloud-aio-nextcloud with ip-address 192.168.96.8
So… I did some experimenting. I will try ports 11000, 80, 443 and 8443. For the two containers, using both the name of the container and the ip address. I will also try localhost, host.docker.internal and 192.168.178.100 (local ip). First trying the 127.0.0.1 as the IP binding for the Apache server, then 0.0.0.0.
And well, it didn’t do anything. With all these tests I also turned on the Cloudflare DNS proxy on again btw.
APACHE_IP_BINDING=127.0.0.1
Apache Container
Container name
Port 11000
Caddyfile
reverse_proxy nextcloud-aio-apache:11000
Caddy logs
msg=dial tcp: lookup nextcloud-aio-apache on 127.0.0.11:53: server misbehaving
status=502
Port 80
Caddyfile
reverse_proxy nextcloud-aio-apache:80
Caddy logs
status=502
Port 443
Caddyfile
reverse_proxy nextcloud-aio-apache:443
Caddy logs
status=502
Port 8443
Caddyfile
reverse_proxy nextcloud-aio-apache:8443
Caddy logs
status=502
IP Address
Port 11000
Caddyfile
reverse_proxy 192.168.96.10:11000
Caddy logs
msg=dial tcp 192.168.96.10:11000: i/o timeout
status=502
Port 80
Caddyfile
reverse_proxy 192.168.96.10:80
Caddy logs
msg=dial tcp 192.168.96.10:80: i/o timeout
status=502
Port 443
Caddyfile
reverse_proxy 192.168.96.10:443
Caddy logs
msg=dial tcp 192.168.96.10:443: i/o timeout
status=502
Port 8443
Caddyfile
reverse_proxy 192.168.96.10:8443
Caddy logs
msg=dial tcp 192.168.96.10:8443: i/o timeout
status=502
Nextcloud container
Container name
Port 11000
Caddyfile
reverse_proxy nextcloud-aio-nextcloud:11000
Caddy logs
msg=dial tcp: lookup nextcloud-aio-nextcloud on 127.0.0.11:53: server misbehaving
status=502
Port 80
Caddyfile
reverse_proxy nextcloud-aio-nextcloud:80
Caddy logs
status=502
Port 443
Caddyfile
reverse_proxy nextcloud-aio-nextcloud:443
Caddy logs
status=502
Port 8443
Caddyfile
reverse_proxy nextcloud-aio-nextcloud:8443
Caddy logs
status=502
IP address
Port 11000
Caddyfile
reverse_proxy 192.168.96.8:11000
Caddy logs
msg=dial tcp 192.168.96.8:11000: i/o timeout
status=502
Port 80
Caddyfile
reverse_proxy 192.168.96.8:80
Caddy logs
msg=dial tcp 192.168.96.8:80: i/o timeout
status=502
Port 443
Caddyfile
reverse_proxy 192.168.96.8:443
Caddy logs
msg=dial tcp 192.168.96.8:443: i/o timeout
status=502
Port 8443
Caddyfile
reverse_proxy 192.168.96.8:8443
Caddy logs
msg=dial tcp 192.168.96.8:8443: i/o timeout
status=502
localhost
Port 11000
Caddyfile
reverse_proxy localhost:11000
Caddy logs
msg=dial tcp 127.0.0.1:11000: connect: connection refused
status=502
Port 80
Caddyfile
reverse_proxy localhost:80
Caddy logs
msg=tls: first record does not look like a TLS handshake
status=502
Port 443
Caddyfile
reverse_proxy localhost:443
Caddy logs
msg=emote error: tls: internal error
status=502
Port 8443
Caddyfile
reverse_proxy localhost:8443
Caddy logs
msg=dial tcp 127.0.0.1:8443: connect: connection refused
status=502
Port 11000
Caddyfile
Caddy logs
status=502
Port 80
Caddyfile
reverse_proxy host.docker.internal:80
Caddy logs
status=502
Port 443
Caddyfile
reverse_proxy host.docker.internal:443
Result
cloud.domain.tld directs to my Openmediavault dashboard.
Port 8443
Caddyfile
reverse_proxy host.docker.internal:8443
Caddy logs
msg=dial tcp 172.17.0.1:8443: i/o timeout
status=502
192.168.178.100
Port 11000
Caddyfile
reverse_proxy 192.168.178.100:11000
Caddy logs
msg=dial tcp 192.168.178.100:11000: i/o timeout
status=502
Port 80
Caddyfile
reverse_proxy 192.168.178.100:80
Caddy logs
status=502
Port 443
Caddyfile
reverse_proxy 192.168.178.100:443
Result
Port 8443
Caddyfile
reverse_proxy 192.168.178.100:8443
Caddy logs
msg=dial tcp 192.168.178.100:8443: i/o timeout
status=502
Apache Container
Container name
Port 11000
Caddyfile
Caddy logs
status=502
Port 80
Caddyfile
Caddy logs
status=502
Port 443
Caddyfile
Caddy logs
status=502
Port 8443
Caddyfile
Caddy logs
status=502
IP Address
Port 11000
Caddyfile
Caddy logs
status=502
Port 80
Caddyfile
Caddy logs
status=502
Port 443
Caddyfile
Caddy logs
status=502
Port 8443
Caddyfile
Caddy logs
status=502
Nextcloud container
Container name
Port 11000
Caddyfile
Caddy logs
status=502
Port 80
Caddyfile
Caddy logs
status=502
Port 443
Caddyfile
Caddy logs
status=502
Port 8443
Caddyfile
Caddy logs
status=502
IP address
Port 11000
Caddyfile
Caddy logs
status=502
Port 80
Caddyfile
Caddy logs
status=502
Port 443
Caddyfile
Caddy logs
status=502
Port 8443
Caddyfile
Caddy logs
status=502
localhost
Port 11000
Caddyfile
Caddy logs
status=502
Port 80
Caddyfile
Caddy logs
status=502
Port 443
Caddyfile
Caddy logs
status=502
Port 8443
Caddyfile
Caddy logs
status=502
Port 11000
Caddyfile
Caddy logs
status=502
Port 80
Caddyfile
Caddy logs
status=502
Port 443
Caddyfile
Result
Port 8443
Caddyfile
Caddy logs
status=502
192.168.178.100
Port 11000
Caddyfile
Caddy logs
status=502
Port 80
Caddyfile
Caddy logs
status=502
Port 443
Caddyfile
Result
Port 8443
Caddyfile
Caddy logs
status=502
Ah I now realize that the
also creates a network: nextcloud-aio. Maybe I should add the caddy container to this network. With this set and APACHE_IP_BINDING=0.0.0.0.
Still no luck…
Tried these variants:
Caddyfile
Caddy logs
status=502
Caddyfile
Caddy logs
status=502
But might the above two error messages show that I am on to something here?
Caddyfile
Caddy logs
status=502
Caddyfile
Caddy logs
status=502
I have the feeling that this is the closest I got to the solution. Caddy is not making the right kind of connection to the nextcloud-apache instance?
I fixed it. This did the trick in the end:
This is my Caddyfile now:
  # Email
  email <email>
  # Debug
  # debug
(cloudflare) {
  import cloudflare
Thank you so much for your help!
For a full walkthrough on how I installed Nextcloud AIO behind Caddy without using the network_mode:“host” you can check:
