I need to convert htaccess to Caddyfile
Hello, I need to convert these htaccess to Caddyfile
This htaccess is at the root of the web
RewriteEngine On
RewriteCond %{REQUEST_URI} !^public
RewriteRule ^(.*)$ public/$1 [L]
And this in the public folder
<IfModule mod_rewrite.c>
<IfModule mod_negotiation.c>
    Options -MultiViews
</IfModule>
RewriteEngine On
# Redirect Trailing Slashes If Not A Folder...
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule ^(.*)/$ /$1 [L,R=301]
# Handle Front Controller...
RewriteCond %{REQUEST_FILENAME} !-f
RewriteRule ^ index.php [L]
# Handle Authorization Header
RewriteCond %{HTTP:Authorization} .
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]</IfModule>
Thanks
Hi @myhumm, welcome to the Caddy community.
What have you tried so far? Do you have a Caddyfile you’re working on?
You can achieve all these with a combination of rewrite, redir, and Placeholders. The examples in the docs should be helpful to getting you started.
https://caddyserver.com/docs/rewrite
https://caddyserver.com/docs/redir
https://caddyserver.com/docs/placeholders
