I need help translate caddyfile to v2
v2.1
mac OS Catalina
paste full file contents here
localhost {
  root dist
  proxy /xxx/v1.0 https://xxx.xxx.xxx
  rewrite {
    if {path} not_starts_with /emoneyKyc/v1.0
    to {path} /
  gzip
  tls self_signed
I need v2 type for this caddyfile I have.
:2015 {
  try_files {path} /index.html
  root dist
  reverse_proxy --from /xxx/v1.0 --to https://xxx.xxx.xxx
  encode zstd gzip
but when i visit my url in local it shows error 500, 502 in the page.
reverse_proxy --from is a CLI command/option. You’re looking for the reverse_proxy directive
Also, in Caddy v2, path matching is exact-match, meaning you’ll need to add a * after /xxx/v1.0 for it to match anything other than exactly /xxx/v1.0.
The rest looks ok to me.
Thank you very much although my information is not that completed above.
I’ll test on this and report back asap.
due to the architect complexity, I guess my problem now is im not able to use caddy to consume my internal API-s it just got 401 from the API, but this is not Caddy problem already, so this post can be closed.
trully appreciate your effort in help checking my caddyfile.
