1. My Caddy version (caddy version
It should support automatically generating a LetsEncrypt for the generated Azure domain name. This is the current part of the docker-compose.yml that pertains to Caddy that would need to be updated as well.
image: abiosoft/caddy
depends_on:
- api
- web
- guide
command: -default-sni HOST_IP -conf /etc/Caddyfile
- ./Caddyfile:/etc/Caddyfile
- ./volumes/caddy:/root/.caddy
- ./keys:/root/keys
paste full file contents here
redir https://{host}{uri}
:443, https://HOST_IP {
tls /root/keys/wildcard.crt /root/keys/wildcard.key
proxy / web:80 {
except /blob /graphql /kibana
proxy /blob api:9000
proxy /graphql api:9000
proxy /kibana api:9000
https://HOST_IP {
proxy / guide:80
I was using version 1, so I need version 2 and I don’t know much about caddy
