[I found a soloution] OMV Docker Compose not building Caddy
Sorry if this is a no brainer issue but I cannot get Docker to compose Caddy. Here is my compose:
Here is the error I get when trying to build it
500 - Internal Server Error
Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LC_ALL=C.UTF-8; export LANGUAGE=; docker compose --file '/NVMEZFS1/NVME/Jellyfin/Caddy/Caddy.yml' --file "/NVMEZFS1/NVME/Jellyfin/Caddy/compose.override.yml" --env-file '/NVMEZFS1/NVME/Jellyfin/global.env' --env-file '/NVMEZFS1/NVME/Jellyfin/Caddy/Caddy.env' up -d 2>&1': Service caddy Building #0 building with "default" instance using docker driver #1 [caddy internal] load build definition from Dockerfile #1 transferring dockerfile: 2B done #1 DONE 0.1s failed to solve: failed to read dockerfile: open Dockerfile: no such file or directory
<!-- What are you trying to do? What isn't working? Please describe the issue thoroughly enough so that anyone can reproduce the exact behavior you're seeing. Be as specific as possible. Use `curl -vL` to show example requests. DO NOT USE WEB BROWSERS HERE. Browsers have subtle caching behaviours which can make testing difficult. -->
    build:
      context: .
      dockerfile: Dockerfile
      - "443:443/udp"
      - /NVMEZFS1/NVME/Jellyfin/Caddy/Caddyfile:/etc/caddy/Caddyfile
      - /NVMEZFS1/NVME/Jellyfin/Caddy/configs/caddy/site:/srv
      - /NVMEZFS1/NVME/Jellyfin/Caddy/caddy_data:/data
      - /NVMEZFS1/NVME/Jellyfin/Caddy/caddy_config:/config
      - caddy-network
  caddy-network:
    external: true
  caddy_data:
    external: true
  caddy_config:
I may have found an alternative no need to reply
Could you elaborate? For the sake of future generations
