I’m trying to restart Caddy and connect to my sites url’s but can’t
× caddy.service - Caddy
Loaded: loaded (/usr/lib/systemd/system/caddy.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Thu 2024-07-04 15:07:07 AEST; 30s ago
Process: 46399 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
Main PID: 46399 (code=exited, status=1/FAILURE)
Status: "loading new config: http app module: start: listening on :80: listen tcp :80: bind: address already in use"
CPU: 81ms
Jul 04 15:07:07 plexserver caddy[46399]: {"level":"info","ts":1720069627.9428687,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jul 04 15:07:07 plexserver caddy[46399]: {"level":"info","ts":1720069627.9567704,"logger":"pki.ca.local","msg":"root certificate is already trusted by system","path":"storage:pki/authorities/local/root.crt"}
Jul 04 15:07:07 plexserver caddy[46399]: {"level":"info","ts":1720069627.9569309,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Jul 04 15:07:07 plexserver caddy[46399]: {"level":"info","ts":1720069627.957072,"msg":"[INFO][FileStorage:/var/lib/caddy/.local/share/caddy] Lock for 'storage_clean' is stale (created: 2024-07-04 14:52:35.209832648 +1000 AEST, last update: 2024-07-04 14>
Jul 04 15:07:07 plexserver caddy[46399]: {"level":"info","ts":1720069627.9571962,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Jul 04 15:07:07 plexserver caddy[46399]: {"level":"info","ts":1720069627.957293,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc000428c00"}
Jul 04 15:07:07 plexserver caddy[46399]: Error: loading initial config: loading new config: http app module: start: listening on :80: listen tcp :80: bind: address already in use
Jul 04 15:07:07 plexserver systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Jul 04 15:07:07 plexserver systemd[1]: caddy.service: Failed with result 'exit-code'.
Jul 04 15:07:07 plexserver systemd[1]: Failed to start caddy.service - Caddy.
I don’t remember, I think I followed a guide on caddy site. But Caddy isn’t installed in Docker.
Ubuntu 24.04
Docker version 26.1.3, build b72abbb
sudo systemctl restart caddy
# domain name.
admin 0.0.0.0:2020
acme_dns XXXX XXXXXXXXXXX
nc.sceptic.au: {
tls internal
reverse_proxy localhost:11000
sonarr.sceptic.au {
tls internal
reverse_proxy 192.168.50.242:8989
homepage.sceptic.au {
tls internal
reverse_proxy localhost:3000
overseerr.sceptic.au {
tls internal
reverse_proxy localhost:5055
maintainerr.sceptic.au {
tls internal
reverse_proxy localhost:6246
radarr.sceptic.au {
tls internal
reverse_proxy localhost:7878
readarr.sceptic.au {
tls internal
reverse_proxy localhost:8787
lidarr.sceptic.au {
tls internal
reverse_proxy localhost:8686
sabnzbd.sceptic.au {
tls internal
reverse_proxy localhost:8089
prowlarr.sceptic.au {
tls internal
reverse_proxy localhost:9696
https://audio.sceptic.au:443 {
tls internal
reverse_proxy localhost:13378
tautulli.sceptic.au {
tls internal
reverse_proxy localhost:8181
paperless.sceptic.au {
tls internal
reverse_proxy localhost:8003
actual.sceptic.au {
tls internal
reverse_proxy localhost:5006
freshrss.sceptic.au {
tls internal
reverse_proxy localhost:8282
immich.sceptic.au {
tls internal
reverse_proxy localhost:2283
dozzle.sceptic.au {
tls internal
reverse_proxy localhost:8888
ukuma.sceptic.au {
tls internal
reverse_proxy localhost:3001
filebrowser.sceptic.au {
tls internal
reverse_proxy localhost:8383
dockge.sceptic.au {
tls internal
reverse_proxy localhost:5001
linkding.sceptic.au {
tls internal
reverse_proxy localhost:9090
change.sceptic.au {
tls internal
reverse_proxy localhost:5000
duplicati.sceptic.au {
tls internal
reverse_proxy localhost:8200
stirlingpdf.sceptic.au {
tls internal
reverse_proxy localhost:8088
wallos.sceptic.au {
tls internal
reverse_proxy localhost:8484
reader.sceptic.au {
tls internal
reverse_proxy localhost:5005
vikunja.sceptic.au {
tls internal
reverse_proxy localhost:3456
watcharr.sceptic.au {
tls internal
reverse_proxy localhost:3080
money-balancer.sceptic.au {
tls internal
reverse_proxy localhost:8030
jelu.sceptic.au {
tls internal
reverse_proxy localhost:11111
readeck.sceptic.au {
tls internal
reverse_proxy localhost:8022
silverbullet.sceptic.au {
tls internal
reverse_proxy localhost:3004
codeserver.sceptic.au {
tls internal
reverse_proxy localhost:8090
scrutiny.sceptic.au {
tls internal
reverse_proxy localhost:8188
mealie.sceptic.au {
tls internal
reverse_proxy localhost:9925
emulator.sceptic.au {
tls internal
bittorrent.sceptic.au {
tls internal
reverse_proxy localhost:8586
hoarder.sceptic.au {
tls internal
reverse_proxy localhost:3088
olivetin.sceptic.au {
tls internal
netalertx.sceptic.au {
tls internal
reverse_proxy localhost:20211
searxng.sceptic.au {
tls internal
reverse_proxy localhost:8092
