I’m trying to easily access my unifi controller using a FQDN with Caddy reverse proxy. I added to my config but I just get a 404 error when I visit the domain. I don’t see anything in the Caddy logs.
smoochii ~/ 23:03 ❯ curl -vL https://unifi.smoochii.dev
* Host unifi.smoochii.dev:443 was resolved.
* IPv6: (none)
* IPv4: 10.10.1.102
* Trying 10.10.1.102:443...
* Connected to unifi.smoochii.dev (10.10.1.102) port 443
* CAfile: /etc/ssl/cert.pem
* CApath: none
* (304) (IN), TLS handshake, Server hello (2):
* (304) (IN), TLS handshake, Unknown (8):
* (304) (IN), TLS handshake, Certificate (11):
* (304) (IN), TLS handshake, CERT verify (15):
* (304) (IN), TLS handshake, Finished (20):
* (304) (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / AEAD-CHACHA20-POLY1305-SHA256 / [blank] / UNDEF
* ALPN: server accepted h2
* subject: CN=unifi.smoochii.dev
* start date: Sep 11 13:30:51 2025 GMT
* expire date: Dec 10 13:30:50 2025 GMT
* subjectAltName: host "unifi.smoochii.dev" matched cert's "unifi.smoochii.dev"
* issuer: C=US; O=Let's Encrypt; CN=E7
* SSL certificate verify ok.
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://unifi.smoochii.dev/
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:authority: unifi.smoochii.dev]
* [HTTP/2] [1] [:path: /]
* [HTTP/2] [1] [user-agent: curl/8.7.1]
* [HTTP/2] [1] [accept: */*]
> GET / HTTP/2
> Host: unifi.smoochii.dev
> User-Agent: curl/8.7.1
* Request completely sent off
< HTTP/2 404
< date: Fri, 03 Oct 2025 03:03:36 GMT
< via: 1.1 Caddy
< content-length: 0
* Connection #0 to host unifi.smoochii.dev left intact
smoochii@caddy:~$ caddy version
I’m running caddy as an LXC in Proxmox installed via Proxmox VE Helper-Scripts
smoochii@caddy:~$ uname -a
Linux caddy 6.8.12-12-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-12 (2025-07-14T13:20Z) x86_64 GNU/Linux
sudo systemctl enable caddy
(cloudflare) {
dns cloudflare <redacted>
pve.smoochii.dev {
reverse_proxy 10.10.1.100:8006 {
tls_insecure_skip_verify
import cloudflare
pbs.smoochii.dev {
reverse_proxy 10.10.1.112:8007 {
import cloudflare
vaultwarden.smoochii.dev {
reverse_proxy 192.168.1.8:8000
import cloudflare
dashboard.smoochii.dev {
reverse_proxy 10.10.10.110:7575
import cloudflare
kasm.smoochii.dev {
reverse_proxy https://192.168.1.9 {
header_up Host {host}
header_up X-Real-IP {remote}
header_up X-Forwarded-For {remote}
header_up X-Forwarded-Port {server_port}
import cloudflare
ha.smoochii.dev {
reverse_proxy 10.10.10.105
import cloudflare
gitea.smoochii.dev {
reverse_proxy 10.10.10.109:3000
import cloudflare
gaming.smoochii.dev {
reverse_proxy 10.10.10.108:8080
import cloudflare
minecraft.smoochii.dev {
reverse_proxy 10.10.1.108:25565
import cloudflare
panel.smoochii.dev {
reverse_proxy 10.10.10.107
import cloudflare
portainer.smoochii.dev {
reverse_proxy 10.10.10.113:9443 {
import cloudflare
nas.smoochii.dev {
reverse_proxy https://192.168.1.23 {
import cloudflare
nextcloud.smoochii.dev {
reverse_proxy 10.10.20.111:443 {
import cloudflare
internal-pihole.smoochii.dev {
redir / /admin{uri}
reverse_proxy 10.10.1.106:8080
import cloudflare
authentik.smoochii.dev {
reverse_proxy 10.10.10.113:9000
import cloudflare
unifi.smoochii.dev {
reverse_proxy /inform https://10.10.1.1:8080
reverse_proxy 10.10.1.1:8443 {
tls
import cloudflare
