From supervisord
Debian 11
[program:mercure]
process_name=%(program_name)s
environment=JWT_KEY="m3rcu353cr37pa55pra53DEV" \MERCURE_PUBLISHER_JWT_KEY="m3rcu353cr37pa55pra53DEV" \MERCURE_SUBSCRIBER_JWT_KEY="m3rcu353cr37pa55pra53DEV" \CORS_ALLOWED_ORIGINS="https://pami54.local" \PUBLISH_ALLOWED_ORIGINS="https://pami54.local" \SERVER_NAME="pami54.local:3000"
command=/home/frizquierdo/mercureLinux/mercure run --config /home/frizquierdo/mercureLinux/Caddyfile
numprocs=1
autostart=true
autorestart=true
startsecs=5
startretries=10
redirect_stderr=false
stdout_capture_maxbytes=1MB
stderr_capture_maxbytes=1MB
stdout_logfile=/var/log/supervisor/mercureout.log
stderr_logfile=/var/log/supervisor/mercureerror.log
supervisord
# Learn how to configure the Mercure.rocks Hub on https://mercure.rocks/docs/hub/config
http_port 8081
{$GLOBAL_OPTIONS}
pami54.local:3000
log
tls /etc/apache2/ssl-cert/pami54.local.crt /etc/apache2/ssl-cert/pami54.local.key
route {
encode zstd gzip
mercure {
# Transport to use (default to Bolt)
transport_url {$MERCURE_TRANSPORT_URL:bolt://mercure.db}
# Publisher JWT key
publisher_jwt {env.MERCURE_PUBLISHER_JWT_KEY} {env.MERCURE_PUBLISHER_JWT_ALG}
# Subscriber JWT key
subscriber_jwt {env.MERCURE_SUBSCRIBER_JWT_KEY} {env.MERCURE_SUBSCRIBER_JWT_ALG}
# Extra directives
cors_origins https://pami54.local
publish_origins https://pami54.local
{$MERCURE_EXTRA_DIRECTIVES}
respond /healthz 200
respond "Not Found" 404
The clients can connect and reconnect to the Mercure hub, but when eb application try to publish into the hub, the HTTP Client component log errors:
messenger.WARNING: Error thrown while handling message App\Message\NotificacionMessage. Sending for retry #3 using 4000 ms delay. Error: "Handling "App\Message\NotificacionMessage" failed: Failed to send an update." {"message":{"App\\Message\\NotificacionMessage":[]},"class":"App\\Message\\NotificacionMessage","retryCount":3,"delay":4000,"error":"Handling \"App\\Message\\NotificacionMessage\" failed: Failed to send an update.","exception":"[object] (Symfony\\Component\\Messenger\\Exception\\HandlerFailedException(code: 0): Handling \"App\\Message\\NotificacionMessage\" failed: Failed to send an update. at /var/www/html/pami54.local/vendor/symfony/messenger/Middleware/HandleMessageMiddleware.php:129)\n[previous exception] [object] (Symfony\\Component\\Mercure\\Exception\\RuntimeException(code: 0): Failed to send an update. at /var/www/html/pami54.local/vendor/symfony/mercure/src/Hub.php:104)\n[previous exception] [object] (Symfony\\Component\\HttpClient\\Exception\\TransportException(code: 0): The request was not processed and can be safely retried at /var/www/html/pami54.local/vendor/symfony/http-client/Response/CommonResponseTrait.php:148)\n[previous exception] [object] (Symfony\\Component\\HttpClient\\Exception\\TransportException(code: 0): The request was not processed and can be safely retried at /var/www/html/pami54.local/vendor/symfony/http-client/Chunk/ErrorChunk.php:65)\n[previous exception] [object] (Amp\\Http\\Client\\Connection\\UnprocessedRequestException(code: 0): The request was not processed and can be safely retried at /var/www/html/pami54.local/vendor/amphp/http-client/src/Connection/DefaultConnectionFactory.php:117)\n[previous exception] [object] (Amp\\Http\\Client\\SocketException(code: 0): Connection to 'pami54.local:443' failed at /var/www/html/pami54.local/vendor/amphp/http-client/src/Connection/DefaultConnectionFactory.php:118)\n[previous exception] [object] (Amp\\Socket\\ConnectException(code: 111): Connection to tcp://pami54.local:443 refused at /var/www/html/pami54.local/vendor/amphp/socket/src/DnsConnector.php:108)"} []
It’s a virtualhost for the app domain:
<VirtualHost 192.168.56.2:80>
ServerName pami54.local
ServerAlias wwww.pami54.local
Redirect permanent / https://pami54.local
</VirtualHost>
<IfModule mod_ssl.c>
#SSLStaplingCache "shmcb:${SRVROOT}/logs/ssl_stapling(32768)"
<VirtualHost 192.168.56.2:443>
DocumentRoot "/var/www/html/pami54.local/public"
DirectoryIndex index.php
<Directory "/var/www/html/pami54.local/public/">
AllowOverride All
Order Allow,Deny
Allow from All
#Require local
Require all granted
<IfModule mod_rewrite.c>
Options -MultiViews
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteRule ^(.*)$ index.php [QSA,L]
</IfModule>
</Directory>
SSLEngine on
SSLProtocol all -SSLv3 -SSLv2
SSLCipherSuite ALL:!ADH:!EXPORT56:RC4+RSA:+HIGH:+MEDIUM:+LOW:+SSLv2:+EXP:+eNULL
SSLCertificateFile "/etc/apache2/ssl-cert/pami54.local.crt"
SSLCertificateKeyFile "/etc/apache2/ssl-cert/pami54.local.key"
SSLUseStapling off
ErrorLog ${APACHE_LOG_DIR}/pami54-vhost-error.log
CustomLog ${APACHE_LOG_DIR}/pami54-vhost-access.log combined
<FilesMatch "\.(cgi|shtml|pl|asp|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
BrowserMatch ".*MSIE.*" nokeepalive ssl-unclean-shutdown downgrade-1.0 force-response-1.0
SSLProxyEngine On
ProxyRequests Off
ProxyPreserveHost On
ProxyPass '/.well-known/mercure' 'https://pami54.local:3000/.well-known/mercure' connectiontimeout=600 timeout=600
ProxyPassReverse '/.well-known/mercure' 'https://pami54.local:3000/.well-known/mercure'
</VirtualHost>
</IfModule>
The idea it’s that Mercure run over port 3000 in the same machine of webserver, and in the vitrtualhost definition exist a reverse proxy rule that redirect /.well-known/mercure to https://pami.local:3000/.well-known/mercure.
As I say, the clients can connect to Mercure hub but the web application can publish on the hub.
