I am banning myself with my bouncer because I am serving my docker virtual network gateway to crowdsec:
cscli alerts list `│ 1 │ Ip:172.50.0.1 │ crowdsecurity/http-bad-user-agent │ US │ 21928 T-MOBILE-AS21928 │ ban:1 │ 2024-03-09 07:27:09.912528318 +0000 UTC │`
I have a stack with caddy-crowdsec-bouncer and a dashboard and caddy container has the with GitHub - WeidiDeng/caddy-cloudflare-ip collection and caddy is configured with trusted_proxies cloudflare.
Cloudflare is delivering the real ip Cf-Connecting-Ip but I don’t know how to serve it to the crowdsec correctly.
I am not an advanced user, I hope this is no a bad topic, I did try to search about it, but if there are suggestions other than use “trusted_proxies” I can’t read too much into them without some kind of example.
client_ip":"172.50.0.1 - all of these are from docker virtual network gateway
remote_ip":"172.50.0.1
X-Forwarded-For":["172.50.0.1"]
Cf-Connecting-Ip":["5.5.5.5."]` - real ip
line: {"level":"debug","ts":1710064973.2757668,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.10.20:5055","duration":2.838332639,"request":{"remote_ip":"172.50.0.1","remote_port":"56586","client_ip":"172.50.0.1","proto":"HTTP/2.0","method":"GET","host":"media.mydomain,.com","uri":"/api/v1/movie/1044302","headers":{"Sec-Fetch-Site":["same-origin"],"X-Forwarded-For":["172.50.0.1"],"Cf-Iplongitude":["0"],"X-Forwarded-Proto":["https"],"Accept-Language":["en-US,en;q=0.5"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Cdn-Loop":["cloudflare"],"Accept-Encoding":["gzip, br"],"Cf-Timezone":["Europe/MYCITY"],"Sec-Fetch-Dest":["empty"],"Cf-Ray":["862278b0188f0bb4-AMS"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:123.0) Gecko/20100101 Firefox/123.0"],"Cf-Iplatitude":["0"],"Referer":["https://media.mydomain.com/"],"Cf-Ipcontinent":["EU"],"Accept":["application/json, text/plain, */*"],"Cookie":[],"Cf-Region":["mycity"],"Cf-Postal-Code":["00000"],"X-Forwarded-Host":["media.mydomain.com"],"Cf-Region-Code":["MY"],"Cf-Ipcity":["MYCITY"],"Cf-Ipcountry":["MY"],"Cf-Connecting-Ip":["5.5.5.5"],"Sec-Fetch-Mode":["cors"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"media.mydomain.com"}},"headers":{"X-Powered-By":["Express"],"Content-Type":["application/json; charset=utf-8"],"Content-Length":["39408"],"Etag":["W/\"99f0-kpMttV9T+0t5WwlerQWxCFsFHwI\""],"Date":["Sun, 10 Mar 2024 10:02:53 GMT"],"Connection":["keep-alive"],"Keep-Alive":["timeout=5"]},"status":200}
The above is taken out of the caddy’s access log, so I think I may have miss configured something really bad, since all I read about it, is that caddy should receive the client_ip without problems
docker-compose up -d (on the entire caddy, crowdsec-bouncer, dashboard stack). The DNS is configured with Cloudflare.
Docker, Linux DS220 4.4.302+ #69057 SMP Fri Jan 12 17:02:28 CST 2024 x86_64 →
RUN xcaddy build \
# dns.providers.cloudflare wraps the provider implementation as a Caddy module.
# http.ip_sources.cloudflare provides a range of IP address prefixes (CIDRs) retrieved from cloudflare.
--with github.com/WeidiDeng/caddy-cloudflare-ip \
# CrowdSec Bouncer - HTTP handler and Layer4 matcher to decide if a request or connection is allowed or not.
--with github.com/hslatman/caddy-crowdsec-bouncer/http
FROM caddy:latest
version: "3.9"
crowdsec:
hostname: crowdsec
image: crowdsecurity/crowdsec:latest
# https://hub.crowdsec.net/author/crowdsecurity/collections/caddy
COLLECTIONS: "crowdsecurity/caddy"
GID: "${PGID}"
DISABLE_ONLINE_API: "true"
depends_on:
- 'caddy'
- 8080:8080 # exposes a REST API for bouncers, cscli and communication between crowdsec agent and local api
- 6060:6060 #exposes prometheus metrics on /metrics and pprof debugging metrics on /debug
- ./crowdsec/acquis.yaml:/etc/crowdsec/acquis.yaml
# Volume mouunted
- crowdsec-db:/var/lib/crowdsec/data/
- crowdsec-config:/etc/crowdsec/
# Caddy database mounted as volume
- ./caddy/logs:/var/log/caddy
caddy_crowdsec:
ipv4_address: 172.50.0.5
# Reverse-proxy-waf definition. Service definition based on docker compose: https://hub.docker.com/_/caddy
# Tutorial by Juan Pablo Tosso: https://medium.com/@jptosso/oss-waf-stack-using-coraza-caddy-and-elastic-3a715dcbf2f2
hostname: caddy
build:
context: ./caddy
dockerfile: Dockerfile #Custom build
# - "1801:80"
- "1443:443"
- $CLOUDFLARE_API_TOKEN
- CROWDSEC_LOCAL_API_KEY=${CROWDSEC_LOCAL_API_KEY}
# Caddy configuration.
- ./caddy/Caddyfile:/etc/caddy/Caddyfile # Required. Needs to be an extension-less file NOT a directory
- ./caddy/caddy_data:/data # Optional, house for certs. Caddy adds its own /caddy/ directory
- ./caddy/caddy_config:/config # Caddy adds its own /caddy/ directory
- ./caddy/logs:/var/log/caddy # check for /access.log
- ./docker/config.json:/etc/caddy/config.json
caddy_crowdsec:
ipv4_address: 172.50.0.6
dashboard:
#we're using a custom Dockerfile so that metabase pops with pre-configured dashboards
build: ./crowdsec/dashboard
MB_DB_FILE: /data/metabase.db
MGID: "${PGID}"
depends_on:
- 'crowdsec'
# bind crowdsec-db for metabase dashboard
- crowdsec-db:/metabase-data/
caddy_crowdsec:
ipv4_address: 172.50.0.9
crowdsec-db:
crowdsec-config:
caddy_crowdsec:
ipam:
driver: default
config:
- subnet: 172.50.0.0/24
order crowdsec first
crowdsec {
api_url http://crowdsec:8080 # the URL where your CrowdSec LAPI can be reached, somewhere on your network/system
api_key {env.CROWDSEC_LOCAL_API_KEY} # the secret API key for the bouncer to authenticate against LAPI
level DEBUG
roll_size 5mb
roll_keep 10
roll_keep_for 720h
servers {
# all traffic come from cloudflare cdn
acme_dns cloudflare {env.CLOUDFLARE_API_TOKEN}
localhost {
route {
crowdsec
respond "Allowed by CrowdSec!"
*.mydomain.com {
@plex host plex.mydomain.com
handle @plex {
crowdsec
reverse_proxy 192.168.10.20:32400
@media host media.mydomain.com
handle @media {
crowdsec
reverse_proxy 192.168.10.20:5055
@photos host photos.mydomain.com
handle @photos {
crowdsec
reverse_proxy 192.168.10.20:2342
# Fallback for otherwise unhandled domains
abort
Tried to add these transform rules, didn’t see any difference and I am sorry in advance that I have redacted the domain and Ip addresses.
