caddy:2.0.0
docker-compose up
Docker
docker-compose up
paste full file contents here
#auto_https off
#auto_https disable_redirects
email email@gmail.com
# reverse proxy trial
:8080 {
reverse_proxy {
#to s3zipper:8000
to :8000
I have a server that runs on port:8000. It can run directly on my localhost or inside docker successfully.
My main problem is that I cannot successfully get my caddy server to reverse proxy into it.
I am somehow missing something.
I seem to be getting different versions of this error
caddyserver | {"level":"error","ts":1596482182.868769,"logger":"http.log.error","msg":"dial tcp: lookup s3zipper on 127.0.0.11:53: no such host","request":{"method":"GET","uri":"/","proto":"HTTP/1.1","remote_addr":"172.27.0.1:48230","host":"localhost:8080","headers":{"Connection":["keep-alive"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:79.0) Gecko/20100101 Firefox/79.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"],"Accept-Language":["en-US,en;q=0.5"],"Accept-Encoding":["gzip, deflate"]}},"duration":0.396482222,"status":502,"err_id":"cekmpfsx7","err_trace":"reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:380)"}
caddyserver | {"level":"error","ts":1596483060.308037,"logger":"http.log.error","msg":"dial tcp :8000: connect: connection refused","request":{"method":"GET","uri":"/","proto":"HTTP/1.1","remote_addr":"172.27.0.1:42714","host":"localhost:8080","headers":{"Sec-Fetch-Site":["none"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36"],"Upgrade-Insecure-Requests":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Mode":["navigate"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["en-GB,en;q=0.9,sw-TZ;q=0.8,sw;q=0.7,en-US;q=0.6"],"Connection":["keep-alive"],"Dnt":["1"]}},"duration":0.000345104,"status":502,"err_id":"670cjjeb2","err_trace":"reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:380)"}
I have made sure that server actually runs . I think the problem is dealing with the connection refused
part.
docker-compose.yml
version: "3"
caddyserver:
image: caddy:2.0.0
container_name: caddyserver
hostname: caddyserver
#user: root
# user: ${CURRENT_UID}
- 80:80
- 8080:8080
- "./caddy_secrets/data_lets_encrypt_storage:/data"
- "./caddy_secrets/config_storage:/config"
mongo:
image: mongo
expose:
- "27017"
awszipper:
build: .
image: awszipper
depends_on:
- 'mongo'
- "8000:8000"
- .:/go
mongo:
