I am not able to obtain an ACME certificate through the cloudflare tunnel
Hello
I am not able to obtain an ACME certificate through the cloudflare tunnel.
The connection diagram is
client → https ->(bnc.xxx.com via cloudflare tunnel) → caddy → https → NextCloud
If the certificate is generated internally, caddy works (tls internal) but the DNS challenge times out.
I am using the correct module and I have added the suggested configuration in each timeout but nothing, there is no way.
In the Cloudflare dashboard I see that the record is created correctly.
P.S: It worked one time, when @timelordx told me that I have to do a DNS challenge but now I’m trying to create another certificate and I only get time outs.
Greetings and thanks in advance
caddy     | {"level":"error","ts":1754503423.4597075,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"bnc.enunlugarignotoeinefable.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[bnc.enunlugarignotoeinefable.com] solving challenges: waiting for solver certmagic.solverWrapper to be ready: timed out waiting for record to fully propagate; verify DNS provider configuration is correct - last error: <nil> (order=https://acme-v02.api.letsencrypt.org/acme/order/2566972211/415143911347) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
FROM caddy:2.10.0-builder AS builder
RUN xcaddy build \\
–with github.com/corazawaf/coraza-caddy/v2@latest \\
–with github.com/hslatman/caddy-crowdsec-bouncer/http@main \\
–with github.com/hslatman/caddy-crowdsec-bouncer/appsec@main \\
–with github.com/hslatman/caddy-crowdsec-bouncer/layer4@main \\
–with github.com/WeidiDeng/caddy-cloudflare-ip \\
–with github.com/mholt/caddy-dynamicdns \\
–with github.com/caddy-dns/cloudflare \\
–with github.com/caddy-dns/duckdns
FROM caddy:2.10.0
Raspbian x64
sudo docker compose up --build in order to see the log
    build:
       context: .
       dockerfile: Dockerfile
    cap_add:
      - NET_ADMIN
      - CLOUDFLARE_API_TOKEN=$CLOUDFLARE_API_TOKEN
      - DUCKDNS_API_TOKEN=$DUCKDNS_API_TOKEN
      - 443:443
#      - 443:443/udp
      - 8123:8123
      - 8443:8443
      - 4080:4080
      - $DOCKERDIR/caddy/log:/var/log
      - $DOCKERDIR/caddy/ruleset:/ruleset
      - $DOCKERDIR/caddy/Caddyfile:/etc/caddy/Caddyfile
      - $DOCKERDIR/caddy/data:/data
      - $DOCKERDIR/caddy/config:/config
      - $DOCKERDIR/certs/:/config/rlyeh
# Aquí irían las webs si siquiera meterlas o las configuraciones específicas para cada URL, como reglas personalizadas CRS
#      - $DOCKERDIR/caddy/site:/srv
      crowdsec:
    security_opt:
      - no-new-privileges=true
  crowdsec:
   image: docker.io/crowdsecurity/crowdsec:latest
   container_name: crowdsec
     - GID=1000
     - COLLECTIONS=crowdsecurity/caddy crowdsecurity/http-cve  crowdsecurity/base-http-scenarios crowdsecurity/appsec-generic-
rules crowdsecurity/linux crowdsecurity/sshd crowdsecurity/whitelist-good-actors crowdsecurity/iptables
     - BOUNCER_KEY_CADDY=${CROWDSEC_API_KEY}
     - 7422:7422
     - $DOCKERDIR/caddy/crowdsec_config:/etc/crowdsec
     - crowdsec_db:/var/lib/crowdsec/data/
     - $DOCKERDIR/caddy/log:/var/log/caddy:ro
     crowdsec:
   security_opt:
  crowdsec_db:
  crowdsec:
    driver: bridge
#Esta es la zona de la definición de configuración global
#Se puedes deshabitar el auto_https para usar certificados propios, sino por defecto Caddy usa unos autofirmados para>
#auto_https off
#Token de la API Cloudflare que usa el módulo para la gestión ACME de Cloudflare
  acme_dns cloudflare {env.CLOUDFLARE_API_TOKEN}
#Configuración para el módulo de aceptar solo el tráfico proveniente del rango de IPs de cloudflare
  servers {
    trusted_proxies cloudflare {
         interval 12h
         timeout 15s
# Definición de duckdns como proveedor DNS par el módulo "caddy-dns/duckdns". Ver documento sobre porque está comentado.
#  dns duckdns {env.DUCKDNS_API_TOKEN}
#Configuración para el módulo de gestión de duckdns
  dynamic_dns {
       provider duckdns {env.DUCKDNS_API_TOKEN}
       domains {
             duckdns.org xxx
# Ponemos el log de debug (crowsec usa los log para detectar anomalías)
   level DEBUG
#Habilitamos coraza
    order coraza_waf first
#Habilitamos y configuramos crowdsec
  crowdsec {
    api_url http://localhost:8080
    api_key <api_key>
    ticker_interval 15s
    appsec_url http://localhost:7422
    disable_streaming
    #enable_hard_fails
#Fin de la zona de configuración global
#Esta es la zona de definición de sites
#Configuración de reserve proxy (esto incluye la configuración para la inspección de coraza)
#Home Assistant
https://bha.xxx.com {
  resolvers 1.1.1.1
  propagation_timeout 10m
#        coraza_waf {
#                load_owasp_crs
#                directives `
#                  Include @coraza.conf-recommended
#                  Include @crs-setup.conf.example
#                   Include @owasp_crs/*.conf
#                   SecRuleEngine On
         reverse_proxy http://192.168.8.22:8123 {
#         header_up X-Real-IP {client_ip}
#         header_up X-Real-IP {remote_host}
           output file /var/log/caddy/homeassistant.log
#NextCloud
https://bnc.xxx.com {
#tls internal
  resolvers 1.1.1.1
#        coraza_waf {
#                load_owasp_crs
#                directives `
#                   SecRuleEngine On
          reverse_proxy https://192.168.8.20:5443 {
                        tls_trust_pool file /config/rlyeh/rlyeh-ca.pem
                output file /var/log/caddy/nextcloud.log
Remove this line. You already have Cloudflare configured per site. Not sure if that would be the cause of your problem, but give it a try and see if it makes any difference.
Hey. Glad to read you :smiley:
I’ll try it. Thanks!!
Worked!! :upside_down_face: :man_facepalming:
Thanks again
