I cannot find any official documentation, that confirms if the
durationfield in Caddy logs refers to the whole request-response time including the time spent in the upstream. The closest thing I found is this, but official documentation on logs fields would be helpful. -
I am trying to debug the performance issues. In our setup, client requests directly go to Caddy, which is being used for custom SSL. For this architecture, the difference between
duration(if the assumption made in point 1 is correct) in Caddy logs and the time client (chrome browser) waits for server response should be comparable. But I am seeing huge difference (~500ms in ‘Waiting for Server Response’ in chrome timings and ~80ms in Caddy logsduration). Even if we accommodate network delays, this is quite high. -
I am seeing a very huge ‘Initial connection’ time in the chrome browser (>900ms) but the load on Caddy machine is quite low (<2% CPU utilization and <8% memory utilisation). Any way by which we can reduce ‘Initial connection’ delays?
Caddy log (with duration ~80ms)
Note: Yes, this is a 301 request. We need to optimize the redirection time.
"level": "info",
"ts": 1735305388.558313,
"logger": "http.log.access.log1",
"msg": "handled request",
"request": {
"remote_ip": "146.190.9.43",
"remote_port": "60133",
"client_ip": "146.190.9.43",
"proto": "HTTP/2.0",
"method": "GET",
"host": "scnv.io",
"uri": "/Z79J",
"headers": {
"Sec-Fetch-User": [
"?1"
"Accept-Encoding": [
"gzip, deflate, br, zstd"
"Sec-Ch-Ua-Mobile": [
"?0"
"1"
"User-Agent": [
"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"
"Accept": [
"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"
"Sec-Fetch-Mode": [
"navigate"
"Priority": [
"u=0, i"
"Sec-Ch-Ua": [
"\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""
"Sec-Ch-Ua-Platform": [
"\"macOS\""
"Sec-Fetch-Site": [
"none"
"Sec-Fetch-Dest": [
"document"
"Accept-Language": [
"en-GB,en;q=0.9"
"tls": {
"resumed": false,
"version": 772,
"cipher_suite": 4865,
"proto": "h2",
"server_name": "scnv.io"
"bytes_read": 0,
"user_id": "",
"duration": 0.078568326,
"size": 0,
"status": 301,
"resp_headers": {
"Content-Language": [
"en"
"Set-Cookie": [
"REDACTED"
"X-Content-Type-Options": [
"nosniff"
"Date": [
"Fri, 27 Dec 2024 13:16:28 GMT"
"Server": [
"Caddy"
"Alt-Svc": [
"h3=\":443\"; ma=2592000"
"Report-To": [
"{\"group\":\"default\",\"max_age\":86400,\"endpoints\":[{\"url\":\"https://scanova.report-uri.com/a/d/g\"}],\"include_subdomains\":true}"
"Strict-Transport-Security": [
"max-age=31536000;includeSubdomains"
"X-Frame-Options": [
"DENY",
"DENY"
"Vary": [
"Accept-Language, Cookie"
"Content-Type": [
"text/html; charset=utf-8"
"Cross-Origin-Opener-Policy": [
"same-origin"
"Referrer-Policy": [
"strict-origin",
"same-origin"
"X-Xss-Protection": [
"1; mode=block"
"Location": [
"https://scanova.io"
"Content-Security-Policy-Report-Only": [],
"Content-Length": [
"0"
v2.8.4
Running as a service on an AWS EC2 machine
ubuntu
No access to the production machine
Since, this is a performance question, will supply if required.
