HTTPS over public IP
Hi. Welcome! :slight_smile:
I want to enable HTTPS on my server without using domain. I have a VM on Google Compute Engine. It has public IP. I’ve tried to generate self-signed certificate for IP using tutorial (link below). HTTP works just fine. I’ve checked all firewall stuff. 443 is enabled.
I’m hosting Telegram bot on that server. I don’t care about domain name and want to stick to the free options. I’m newbie on all that servers thing. Please help.
Safari can’t open the page “https://35.184.31.227” because Safari can’t establish a secure connection to the server “35.184.31.227”.
latest
with apt install
Ubuntu 18 on Google Compute Engine.
35.184.31.227 {
	tls /home/user/ssl/cert.pem /home/user/ssl/key.pem
	root * /usr/share/caddy
	reverse_proxy localhost:8080
	# php_fastcgi localhost:9000
### 5. Links to relevant resources:
https://medium.com/@antelle/how-to-generate-a-self-signed-ssl-certificate-for-an-ip-address-f0dd8dddf754
Hello, as you do not confirm that caddy has permission to read the certificate in the user’s home directory, you could try to get it running first with caddy’s local CA to get rid of other issue. Once it work, go further.
If you want to try it, write tls internal in the config.
35.184.31.227 {
  # use internal caddy CA
  tls internal
If it still doesn’t work, run the following command: caddy trust
You’re much better off getting a free domain like from DuckDNS or similar.
I ended up buying domain name. Thanks!
