docker.io/caddy/caddy:latest, v2.0.0-rc.3
I’m running Caddy in Podman on server. The server can accessed by server.lan
podman version 3.3.1
Cockpit/Web console 251.1
Almalinux 8.5
sudo podman run \
--detach \
--publish 443:443 \
--volume /home/[USER]/containers/caddy/data:/data:Z \
--volume /home/[USER]/containers/caddy/Caddyfile:/etc/caddy/Caddyfile:Z \
caddy
I’m not using this.
jellyfin.server.lan {
tls internal
reverse_proxy http://localhost:8096
caddy fmt returns fmt: reading input file: open Caddyfile: no such file or directory. I’m not sure why because the Caddyfile exists in home/[USER]/containers/caddy/Caddyfile
On the same server I have Jellyfin running. I like to access Jellyfin by https://jellyfin.server.lan in a browser on my local network. I don’t want to expose it to the internet just to my local network.
Ideally I like to add additional services in the Caddyfile like https://vaultwarden.server.lan, https://homeassistant.server.lan etc.
Entering https://jellyfin.server.lan returns This site can’t be reached
$ curl -v https://server.lan
* Trying 192.168.1.65:443...
* Connected to server.lan (192.168.1.65) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
* CApath: none
* TLSv1.3 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: unable to get local issuer certificate
* Closing connection 0
curl: (60) SSL certificate problem: unable to get local issuer certificate
how to fix it, please visit the web page mentioned above.
$ curl -v https://jellyfin.server.lan
* Could not resolve host: jellyfin.server.lan
curl: (6) Could not resolve host: jellyfin.server.lan
I’ve copied the root.crt and added it to Firefox. But I guess that won’t be an issue since it is not possible to resolve the host.
I’ve tried to follow this example Use Caddy as a reverse proxy (+ local CA!)
