curl -vL https://thedomain.com
TCP_NODELAY set
    Connected to thedomain.com (x.x.x.x) port 443 (#0)
    ALPN, offering h2
    ALPN, offering http/1.1
    successfully set certificate verify locations:
    CAfile: /etc/ssl/certs/ca-certificates.crt
    CApath: /etc/ssl/certs
    TLSv1.3 (OUT), TLS handshake, Client hello (1):
    TLSv1.3 (IN), TLS alert, internal error (592):
    error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
    Closing connection 0
==================== open ssl command gives ==============
openssl s_client -connect thedomain:443
CONNECTED(00000003)
140225236829504:error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error:../ssl/record/rec_layer_s3.c:1543:SSL alert number 80
Using docker image run it with docker compose and php-fpm
Ubuntu 22.04
thedomain.com {
root * /srv/public
php_fastcgi accounts-fpm:9000
