Caddy equivalent code for specific sections of the WordPress support article HTTPS for WordPress.
Best Practices for HTTPS for WordPress #
The Caddy web server activates HTTPS by default for qualifying domain names and automatically enables HTTP → HTTPS redirects. By default, it obtains certificates from Let’s Encrypt and renews them automatically.
example.com {
# Set this path to your site's directory:
root * /var/www/html
# Enable Gzip compression:
# Serve WordPress PHP files through php-fpm:
# Enable the static file server:
Depending on your PHP-FPM config, the php_fastcgi can also be php_fastcgi 127.0.0.1:9000.
Credits and References
Credits
@francislavoie for his contributions within the development reference.
