Http3 not working on non-curl clients
I am trying to do a performance comparison on the frontend for http1.1 vs http2 vs http3 server. I was able to get http1.1 and http2 server working locally using docker fairly easily, however getting http3 to work has been a tedious task. The ymuski/curl-http docker image has shown the response to be http3, but I want to test this on any browser only (Tested on chrome/edge - latest versions) - https://protocol.rahulmakhija.in
I have even taken the trouble of setting this up on a remote linode server, but getting the same results.
My Caddyfile
  servers {
    protocols h1 h2 h2c h3
protocol.rahulmakhija.in {
  tls rahul@example.com
  root * /usr/share/caddy/html
  file_server browse
  header Custom-Header "My value"
My docker-compose.yaml
 http-caddy3:
    image: caddy:2.8.4
      - "443:443/udp"
      - ./caddy/http3/Caddyfile:/etc/caddy/Caddyfile
      - ./src:/usr/share/caddy/html
Dockerfile
# Use the official Caddy image from Docker Hub
FROM caddy:2.8.4
# Copy static assets to Nginx
COPY src/img /usr/share/caddy/html/img
COPY src/index.html /usr/share/caddy/html/
# Copy your Caddyfile to the container
# Expose the port Caddy will run on
EXPOSE 80
EXPOSE 443
# Start Caddy
CMD ["caddy", "run", "--config", "/etc/caddy/Caddyfile"]
docker
docker compose up --force-rebuild
Tried referring to other threads here, but nothing helped. Starting a thread as I want this working on browser only for performance benchmarking reasons.
Nevermind. This was a browser caching issue (Worked on Edge 129 version)
Hard reload was required. (I had tried on a new incognito browser but it still took it from cache?)
How can I get this working locally using http3 & browser ? (while using Dockerfile)
I have copied my root.crt from dockerfile and applied it successfully to get https on localhost but its only working on http2 (tested on chrome & edge)
localhost {
  file_server browse
That’s not really a problem with Caddy. Browsers will do what they want. They typically only try HTTP/3 after seeing the Alt-Svc header from the server, but usually if the response is so fast with HTTP/2 it doesn’t have a reason to try it.
