1. Caddy version (v2.2.1 h1:Q62GWHMtztnvyRU+KPOpw6fNfeCD3SkwH7SfT1Tgt2c=
Windows Server 2019 Standard
2020/10/22 10:20:15.888 e[34mINFOe[0m using adjacent Caddyfile
2020/10/22 10:20:15.907 e[34mINFOe[0m admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2020/10/22 10:20:15.911 e[34mINFOe[0m tls.cache.maintenance started background certificate maintenance {"cache": "0xc000932d20"}
2020/10/22 10:20:15.913 e[34mINFOe[0m http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2020/10/22 10:20:15.917 e[34mINFOe[0m http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2020/10/22 10:20:15.922 e[34mINFOe[0m http enabling automatic TLS certificate management {"domains": ["request.kierenconnell.com"]}
2020/10/22 10:20:15.930 e[34mINFOe[0m tls cleaned up storage units
2020/10/22 10:20:15.958 e[34mINFOe[0m autosaved config {"file": "C:\\Users\\Administrator\\AppData\\Roaming\\Caddy\\autosave.json"}
2020/10/22 10:20:15.959 e[34mINFOe[0m serving initial configuration
N/A
request.kierenconnell.com {
tls notflixserver@gmail.com {
dns cloudflare ########################################
output file C:\Plex\Caddy\logs\ombi_access.log {
roll true # Rotate logs, enabled by default
roll_size_mb 5 # Set max size 5 MB
roll_gzip true # Whether to compress rolled files
roll_local_time true # Use localhost time
roll_keep 2 # Keep at most 2 log files
roll_keep_days 7 # Keep log files for 7 days
reverse_proxy localhost:5000
request.kierenconnell.com serves up the correct page under http and works perfectly fine
https://request.kierenconnell.com serves up ERR_SSL_PROTOCOL_ERROR
N/A
I have port forwarding set up for ports 443 and 80 to port 5000 from my Ubiquti Gateway through to my server
