HTTP status code 0 in Caddy logs for a reverse proxy (with template)
1. Caddy version:
docker
Docker on Ubuntu 20.20
# Production frontend and backend and docs
# PYramid backend API server is localhost:3456
# SvelteKit Node.js frontend SSR server is localhost:3000
http://example.com {
    # Backend API request
    handle /api* {
        # This is the upstream Waitress server
        reverse_proxy 127.0.0.1:3456 {
            # Backend API must respond to an individual API call under 20s seconds
                response_header_timeout 20s
    # Special URL endpoint for Google and other bots
    # that are robots.txt blocked from API
    handle_path /sitemap/* {
        # Same as /api, just a path rewrite using Caddy handle_path
        # https://webinstall.dev/caddy/
        rewrite * /api{path}
    # Serve docs as files rsync'ed to the server
    # See trading-strategy/.github/workflows/rsync-docs.yml for more details
    # https://caddy.community/t/caddy-file-server-browse-not-working-when-root-a-specific-directory/15342/3
    redir /docs /docs/
    handle_path /docs* {
        # See docker-compose
        # mapped to /home/docs/html
        root * /docs
    # SvelteKit production server from frontend repository
        reverse_proxy 127.0.0.1:3000 {
            # Frontend must render the page under 20 seconds
    # Set the default 404 page
    # https://caddyserver.com/docs/caddyfile/directives/handle_errors
    handle_errors {
        respond "{http.error.status_code} {http.error.status_text}"
    # Create a log file log {
        format json
        #output stdout
        # Caddy cannot have two log outputs at the same time
I am grepping through Caddy JSON access logs and sometimes I see HTTP status code (status field) set to zero. What does this mean?
Caddy log JSON object:
{"level":"info","ts":1674820082.9167147,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_addr":"zzzzz,"proto":"HTTP/1.1","method":"GET","host":"tradingstrategy.ai","uri":"zzzzzzz","headers":{"Cdn-Loop":["cloudflare"],"Accept-Encoding":["gzip"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Cf-Ipcountry":["SG"],"Cf-Connecting-Ip":["zzzzz"],"Connection":["Keep-Alive"],"X-Forwarded-For":["139.180.132.162"],"Cf-Ray":["790141cc89a86c06-SIN"],"X-Forwarded-Proto":["https"]}},"common_log":"zzzzz - - [27/Jan/2023:11:48:02 +0000] \"GET /api/zzzzz HTTP/1.1\" 0 0","duration":0.00009558,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}```
Google.
That’s a very old version. Please upgrade to v2.6.2.
Status code 0 is the same as an HTTP 200 status response. It usually happens when the request goes unhandled by Caddy (as in no configured routes wrote a response).
Is that request for a different hostname? It looks like your server is only listening for HTTP requests for example.com. If a different hostname is used, then Caddy won’t handle it because it doesn’t match example.com, so it writes an empty response.
Thank you Francis. Your reply gave me a hint. I believe status code 0 responses are just random bot traffic to the IP address that has nothing to do with my server.
That’s typically the case, yeah. There’s lots of bots crawling the web, making requests to try to find exploitable vulnerabilities. Most of that traffic is harmless and can be ignored.
