First - again thanks for nice software and you work.
Now, let’s get to the business.
I have a situation, that I am using http.proxy to serve some content with Caddy as a frontend. In order to know that I am talking with correct backend, I want to use https:// endpoint. As my backend’s certificates are signed by our own CA, I am currently forced to use insecure_skip_verify. This results, that I can’t verify my backends.
What about just adding your CA to the system’s trust store?
Ok. On system level I shall add something to where package ca-certificates work. But I am compiling my own go and compiling caddy by myself. (Now it maybe becomes go question, but)…
Can I convince go during compilation (or runtime for each caddy running process?!) to point it to different CA store and then put my CA certificates there? I did a (too) short research about it (googled for golang ca trust store) and found How To Trust Extra CA Certs In Your Go App · for func() sake { }, but this is development-level thing, even if they propose similar approach, it is not specific enough to help me.
On UNIX systems the environment variables SSL_CERT_FILE and SSL_CERT_DIR can be used to override the system default locations for the SSL certificate file and SSL certificate files directory, respectively.
I am giving it a try in my crazy environment, I’ll let you know.
But yeah, I’ve never seen anyone bother with a solution other than simply copying the root cert to /usr/local/share/ca-certificates and running sudo update-ca-certificates.
