Http proxy https insecure
I am performing a forwarding proxy for my internal network (router) which does not have an https certificate but when I do it this way, HTTP ERROR 502 appers..
Image for problem:
When access the 100.75.1.90:
        route /https* {
                reverse_proxy 100.75.1.90 {
                        header_up Host 100.75.1.90
                        lb_policy round_robin
                        lb_try_duration 5s
                        health_status 200
                        health_interval 10s
                        fail_duration 30s
                            tls_insecure_skip_verify
        output file /var/log/access.log
v2.7.6
Via apt-get
Ubuntu 22.04 x64_86
systemctl restart caddy
  GNU nano 6.2        /etc/caddy/Caddyfile
# domain name.
        route /https* {
                        lb_try_duration 5s
                        health_status 200
                        health_interval 10s
                        fail_duration 30s
None
You configured Caddy to only listen on port 80, so of course HTTPS will not work.
The default port when none is specified is 80. If you meant to connect over HTTPS, you probably wanted port 443, so specify that.
You don’t need this twice in your config, only the last one will take effect anyway. Remove one of these.
Thanks for reply
Tree questions:
  1. Using caddy via https i can proxies sites insecures? (whithout https)
  2. I can access http sites over https from caddy too?
  3. Can Caddy see if the dest of the proxy is http or https? Is there a way?
Think of incoming connections to Caddy and outgoing connections from reverse_proxy as separate things. One can be HTTP and the other HTTPS, there’s no requirement that they match.
Thank you very much, you shed some light on Caddy for me… but I have a need which is to act as a proxy for both HTTP and HTTPS.
Example:
mysite.net.br/access/100.75.1.90
This address can be either HTTP or HTTPS with an invalid certificate.
In this scenario, do you think I can use Caddy for this issue, or do you recommend any other auxiliary tool?
You’re probably looking for a layer4 TCP proxy instead.
You can use GitHub - mholt/caddy-l4: Layer 4 (TCP/UDP) app for Caddy
Do you have any examples or recommendations for my scenario?
I think the README explains. If you’re looking to pass through connections to your upstream without terminating TLS, then you want caddy-l4 (or any other layer4 proxy) and not an HTTP server/proxy.
I’m not developing this project, if anyone has any sketches or tips… I couldn’t install l4-caddy using Ubuntu, Debian, Alpine…
What did you try, exactly? What problems did you have? If you don’t say then we can’t help.
