I have a (big dynamic) list of known domains, that Caddy should serve. Each has its own site block (generated via template outside of Caddy), using only the domain name (w/o scheme, so e.g. example.com). This works fine so far (auto HTTP/HTTPS redirects too).
I want to have a catch all HTTP block, to display a static error page for unknown domains (i.e. everything with no site block), so I added this block too:
http:// {
root /srv/http/unknown_domain
import logs UNKNOWN
import assets
import fileserver
Here are the includes:
(logs) {
roll_size 50MiB
roll_keep 0
roll_keep_for 24h
format append {
fields {
account "{args[:]}"
wrap filter {
fields {
request>remote_ip delete
request>headers>Accept-Encoding delete
request>headers>Accept delete
request>headers>Connection delete
request>tls delete
request>remote_port delete
resp_headers delete
wrap json {
time_format iso8601
(fileserver) {
file_server {
hide .git .hg .htaccess
index index.html index.htm nocontent.html
{args[:]}
encode {
gzip
minimum_length 1024
(assets) {
handle_path /assets/* {
import fileserver root /srv/http/_assets
This generally does work (the page is shown for unknown domains, known domains are still redirected to HTTPS), but all HTTP request for known domains are logged with field account=UNKNOWN.
I suspect I can work around this by adding manual redirects for all known domains, but I hope I can avoid this. I was a bit surprised, that the http:// site block is even called for request, that would fit a site block w/o scheme.
I feel this part of the docs is crucial:
If you already have a server listening on the HTTP port, the HTTP-HTTPS redirect routes will be inserted after your routes with a host matcher, but before a user-defined catch-all route.
But I have not found a way to prevent this yet…
No errors per se…
Just that every HTTP request for a “known domain” (i.e. one for which a site block is defined) is logged as an “unknown domain” (b/c of the http:// catchall logging config).
v2.10.0
pacman -s caddy
systemctl start caddy
Arch Linux
admin "unix//run/caddy/admin.socket"
persist_config off
email dev+tls-brutus.uberspace.de@uberspace.de
default_sni brutus.uberspace.de
skip_install_trust
log default {
output stderr
format console
metrics {
per_host
grace_period 5s
servers :443 {
name https
servers :80 {
name http
(logs) {
# ARGS: account name
roll_size 50MiB
roll_keep 0
roll_keep_for 24h
format append {
fields {
account "{args[:]}"
wrap filter {
fields {
request>tls delete
resp_headers delete
wrap json {
time_format iso8601
(fileserver) {
# ARGS: extra args for `file_server` directive
file_server {
{args[:]}
encode {
gzip
minimum_length 1024
(assets) {
# UNKNOWN DOMAINS - Catchall
http:// {
import logs UNKNOWN
import assets
import fileserver
# KNOWN DOMAINS
# might be a lot more entries like this…
brutus.uber8.space {
root /srv/http/_accounts/brutus/html
import logs brutus
on_demand
import fileserver
