Http/3 is not working when I removed “experimental_http3”: true
1. Output of caddy version:
v2.6.1 h1:EDqo59TyYWhXQnfde93Mmv4FJfYe00dO60zMiEt+pzo=
Caddy as a reverse proxy in docker container on Digital Ocean
Docker
Paste command here.
Paste your config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
HTTP/3 not working
I removed “experimental_http3”: true, from the previous config on caddy 2.4.6
and thought h1, h2, h3 is default
but now http/3 and even 2 not working when I test on geekflare.com
Do I have to add it to my config.json?
any help would be great, thanks
Caddy’s HTTP/3 works.
Geekflare is broken.
Use curl --http3 -v to verify.
See also:
https://twitter.com/_francislavoie/status/1577769626888507409
https://twitter.com/mholt6/status/1575208886264508417
