.htaccess rewrite question
Im trying to convert a (simple) .htaccess to a caddy file, but i stucked. The original htaccess is the following
RewriteEngine On
RewriteCond %{REQUEST_URI} admin/uploads/.*
RewriteRule ^admin/uploads/(.*)$ uploads/$1 [L]
RewriteCond %{REQUEST_URI} admin/gate/.*
RewriteRule ^admin/gate/(.*)$ gate/$1 [L]
this application is installed in an subdirectory called /map
so i write the following in the Caddyfile
rewrite /map/admin/uploads/(.*) /uploads/{1}
rewrite /map/admin/gate/(.*) /gate/{1}
PHP communicaton error
If i use apache it works, so i am pretty sure that i misconfigured something
My version:
I have installed caddy with Ubuntu 20.04 (package). The Service is running with systemd
systemctl status caddy
my.domain.tld {
  root * /var/www/my.domain.tld/docs
    level error
    output file /var/www/my.domain.tld/logs/access.log
  php_fastcgi unix//run/php/php7.4-fpm.appintern.sock
You can do it like this:
@uploads path_regexp uploads /map/admin/uploads/(.*)
rewrite @uploads /uploads/{re.uploads.1}
@gate path_regexp gate /map/admin/gate/(.*)
rewrite @gate /gate/{re.gate.1}
Hi @francislavoie
thank you, and again you safe my day. Your solution is right, I only have to change the rewrite rule a bit, so the working config looks like:
rewrite @uploads /map/uploads/{re.uploads.1}
rewrite @gate /map/gate/{re.gate.1}
