How to write a elegant reverse_proxy Caddyfile
v2.4.3
Systemd
Ubuntu 18.04
/usr/local/bin/caddy run --environ --config /data/conf/caddy/Caddyfile
Type=notify
User=root
Group=root
ExecStart=/usr/local/bin/caddy run --environ --config /data/conf/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /data/conf/caddy/Caddyfile
I replaced Nginx with Caddy as a reverse proxy.
This is architecture of my site:
  • /static/* is for static files like javascript and css
  • /media/* is for static files which is uploaded by user, like avatar images
  • /admin/* is a administrator panel, which is in the 127.0.0.1:8080
  • /*, the rest of the pages is the user interface, which is in the 127.0.0.1:8081
These things in the Nginx is like that:
server {
    listen 80;
    server_name example.com;
    location ~ /(static|media)/ {
        root /data/;
        expires 30d;
    location /admin/ {
        proxy_pass 127.0.0.1:8080;
    location / {
        proxy_pass 127.0.0.1:8081;
But the Caddyfile is difficult to understand rather than Nginx (for me), and how to write a elegant configuration for my Caddy server?
Pretty simple:
example.com {
	@static path /static/* /media/*
	handle @static {
		root * /data
	handle /admin/* {
		reverse_proxy 127.0.0.1:8080
		reverse_proxy 127.0.0.1:8081
  • Named matcher @static with a path matcher for those two static file locations
  • Inline path matcher for /admin/*
  • handle blocks to implement mutual exclusivity between each (similar to location in nginx) with the last one without a matcher being fallback
Thank you, it works!
