How to use webdav on caddy docker-compose
Hello! Friend.
I use this caddy. Docker Hub
But webdav can not work.
Can you help me ?
I read this page
Module http.handlers.webdav does not come with Caddy.
Then, how to add webdav in caddy docker-compose ?
Did the instructions on that page not work? Under “Adding custom Caddy modules”.
How to add it to docker-compose.yml ?
root@localhost:~# docker-compose up --build
Creating network "root_default" with the default driver
Building caddy
Step 1/4 : FROM caddy:builder AS builder
builder: Pulling from library/caddy
188c0c94c7c5: Already exists
0ef7d3d256c8: Already exists
de9db76c5a1d: Already exists
f5b5e3429cf3: Already exists
07aa6a096151: Already exists
58fe1a629618: Pull complete
e1da5ba704ae: Pull complete
572698d0ecf1: Pull complete
Digest: sha256:11b6dc688f10fd45996d660117a4567192599b9dc33e0ed69376f3e771473085
Status: Downloaded newer image for caddy:builder
 ---> d52e2ef96ee9
Step 2/4 : RUN xcaddy build     --with github.com/mholt/caddy-webdav
 ---> Running in b380fb156d70
2020/12/07 17:12:40 [INFO] Temporary folder: /tmp/buildenv_2020-12-07-1712.680422176
2020/12/07 17:12:40 [INFO] Writing main module: /tmp/buildenv_2020-12-07-1712.680422176/main.go
2020/12/07 17:12:40 [INFO] Initializing Go module
2020/12/07 17:12:40 [INFO] exec (timeout=10s): /usr/local/go/bin/go mod init caddy
go: creating new go.mod: module caddy
2020/12/07 17:12:40 [INFO] Pinning versions
2020/12/07 17:12:40 [INFO] exec (timeout=0s): /usr/local/go/bin/go get -d -v github.com/caddyserver/caddy/v2@v2.2.1
go: downloading github.com/caddyserver/caddy/v2 v2.2.1
go: downloading go.uber.org/zap v1.15.0
go: downloading golang.org/x/crypto v0.0.0-20200728195943-123391ffb6de
go: downloading github.com/caddyserver/certmagic v0.12.0
go: downloading github.com/prometheus/client_golang v1.7.1
go: downloading go.uber.org/atomic v1.6.0
go: downloading github.com/klauspost/cpuid v1.2.5
go: downloading github.com/prometheus/common v0.10.0
go: downloading github.com/cespare/xxhash v1.1.0
go: downloading github.com/mholt/acmez v0.1.1
go: downloading github.com/cespare/xxhash/v2 v2.1.1
go: downloading github.com/golang/protobuf v1.4.2
go: downloading github.com/miekg/dns v1.1.30
go: downloading golang.org/x/sys v0.0.0-20200615200032-f1bc736245b1
go: downloading github.com/matttproud/golang_protobuf_extensions v1.0.1
go: downloading github.com/prometheus/procfs v0.1.3
go: downloading golang.org/x/net v0.0.0-20200707034311-ab3426394381
go: downloading google.golang.org/protobuf v1.24.0
go: downloading github.com/libdns/libdns v0.1.0
go: downloading go.uber.org/multierr v1.5.0
go: downloading github.com/prometheus/client_model v0.2.0
go: downloading golang.org/x/text v0.3.2
go: downloading github.com/beorn7/perks v1.0.1
2020/12/07 17:13:04 [INFO] exec (timeout=0s): /usr/local/go/bin/go get -d -v github.com/mholt/caddy-webdav
go: downloading github.com/mholt/caddy-webdav v0.0.0-20200916200058-c949b3226234
go: github.com/mholt/caddy-webdav upgrade => v0.0.0-20200916200058-c949b3226234
go: downloading github.com/google/cel-go v0.5.1
go: downloading google.golang.org/genproto v0.0.0-20200806141610-86f49bd18e98
go: downloading github.com/smallstep/certificates v0.15.4
go: downloading github.com/lucas-clemente/quic-go v0.18.0
go: downloading github.com/cheekybits/genny v1.0.0
go: downloading github.com/smallstep/cli v0.15.2
go: downloading github.com/marten-seemann/qpack v0.2.0
go: downloading github.com/smallstep/truststore v0.9.6
go: downloading github.com/marten-seemann/qtls-go1-15 v0.1.0
go: downloading github.com/marten-seemann/qtls v0.10.0
go: downloading github.com/antlr/antlr4 v0.0.0-20200503195918-621b933c7a7f
go: downloading howett.net/plist v0.0.0-20181124034731-591f970eefbb
go: downloading github.com/pkg/errors v0.9.1
go: downloading github.com/urfave/cli v1.22.2
go: downloading github.com/chzyer/readline v0.0.0-20180603132655-2972be24d48e
go: downloading github.com/manifoldco/promptui v0.7.0
go: downloading github.com/shurcooL/sanitized_anchor_name v1.0.0
go: downloading github.com/samfoo/ansi v0.0.0-20160124022901-b6bd2ded7189
go: downloading github.com/cpuguy83/go-md2man v1.0.10
go: downloading github.com/juju/ansiterm v0.0.0-20180109212912-720a0952cc2a
go: downloading github.com/mattn/go-colorable v0.1.6
go: downloading github.com/lunixbochs/vtclean v1.0.0
go: downloading github.com/mattn/go-isatty v0.0.12
go: downloading github.com/cpuguy83/go-md2man/v2 v2.0.0
go: downloading github.com/russross/blackfriday v1.5.2
go: downloading github.com/russross/blackfriday/v2 v2.0.1
go: downloading github.com/Masterminds/sprig/v3 v3.1.0
go: downloading github.com/smallstep/nosql v0.3.0
go: downloading go.step.sm/crypto v0.6.0
go: downloading github.com/spf13/cast v1.3.1
go: downloading github.com/imdario/mergo v0.3.9
go: downloading github.com/huandu/xstrings v1.3.1
go: downloading github.com/mitchellh/copystructure v1.0.0
go: downloading github.com/Masterminds/goutils v1.1.0
go: downloading github.com/Masterminds/semver v1.4.2
go: downloading github.com/dgraph-io/badger v1.5.3
go: downloading github.com/google/uuid v1.1.1
go: downloading gopkg.in/square/go-jose.v2 v2.5.1
go: downloading go.etcd.io/bbolt v1.3.2
go: downloading github.com/mitchellh/reflectwalk v1.0.0
go: downloading github.com/Masterminds/semver/v3 v3.1.0
go: downloading github.com/go-sql-driver/mysql v1.5.0
go: downloading github.com/dgryski/go-farm v0.0.0-20190423205320-6a90982ecee2
go: downloading github.com/AndreasBriese/bbloom v0.0.0-20190306092124-e2d15f34fcf9
go: downloading github.com/dgraph-io/badger/v2 v2.0.1-rc1.0.20200413122845-09dd2e1a4195
go: downloading github.com/dgraph-io/ristretto v0.0.2-0.20200115201040-8f368f2f2ab3
go: downloading github.com/DataDog/zstd v1.4.1
go: downloading github.com/golang/snappy v0.0.1
go: downloading github.com/dustin/go-humanize v1.0.1-0.20200219035652-afde56e7acac
go: downloading google.golang.org/grpc v1.27.1
2020/12/07 17:13:19 [INFO] Build environment ready
2020/12/07 17:13:19 [INFO] Building Caddy
2020/12/07 17:13:19 [INFO] exec (timeout=0s): /usr/local/go/bin/go build -o /usr/bin/caddy -ldflags -w -s -trimpath
go: downloading github.com/jsternberg/zap-logfmt v1.2.0
go: downloading gopkg.in/natefinch/lumberjack.v2 v2.0.0
go: downloading github.com/yuin/goldmark v1.2.1
go: downloading github.com/naoina/toml v0.1.1
go: downloading github.com/yuin/goldmark-highlighting v0.0.0-20200307114337-60d527fdb691
go: downloading github.com/klauspost/compress v1.11.0
go: downloading github.com/alecthomas/chroma v0.8.0
go: downloading github.com/go-chi/chi v4.1.2+incompatible
go: downloading gopkg.in/yaml.v2 v2.3.0
go: downloading github.com/rs/xid v1.2.1
go: downloading github.com/naoina/go-stringutil v0.1.0
go: downloading github.com/sirupsen/logrus v1.4.2
go: downloading github.com/danwakefield/fnmatch v0.0.0-20160403171240-cbb64ac3d964
go: downloading github.com/dlclark/regexp2 v1.2.0
2020/12/07 17:15:11 [INFO] Build complete: caddy
2020/12/07 17:15:11 [INFO] Skipping cleanup as requested; leaving folder intact: /tmp/buildenv_2020-12-07-1712.680422176
Removing intermediate container b380fb156d70
 ---> 2b37c05f3f68
Step 3/4 : FROM caddy:builder
 ---> d52e2ef96ee9
Step 4/4 : COPY --from=builder /usr/bin/caddy /usr/bin/caddy
 ---> fdd48aec5c83
Successfully built fdd48aec5c83
Successfully tagged root_caddy:latest
caddy exited with code 0
    # image: caddy
    build: /data/docker/data/caddy
    #  context: /data/docker/data/caddy/
    #  dockerfile: Dockerfile
      - /data/docker/data/caddy/Caddyfile:/etc/caddy/Caddyfile
      - /data/www:/www
      - /data/docker/data/caddy/caddy_data:/data
      - /data/docker/data/caddy/caddy_config:/config
    depends_on:
      - v2ray
      - aria2-pro
      - filebrowser
      - webdav
RUN xcaddy build \
FROM caddy:builder
It’s not working
What’s not working? Just saying “it’s not working” doesn’t tell us anything at all. Please be specific.
